Author Topic: What is this sensor?  (Read 2840 times)
Offline russ-vdub
  • Once a Dub, Always a Dub
Re: What is this sensor?
« Reply #10 on: 31 March 2008, 14:11 »
check the advance at 2500 revs, if it advances to +30 then its ok
i know a bit about timing but you talkin bout gettin a strobe on and reving it to 2500 and check ithat with the flywheel mark? cos i got a snap on timimg jobby from my mechanic, can i use this yeh?
oh and 30+? whats this mean?
Offline russ-vdub
« Reply #11 on: 31 March 2008, 14:27 »
oh and my knock sensor was pretty damn tight, torque it up now and the engines SOOO much smoother, crazy!
Offline lordbigsack
« Reply #12 on: 31 March 2008, 14:32 »
resize that pic mate, it's a bit large  :laugh:
Done!
Cheers for advice, is that the reason it is running a bit lumpy about 3000-4000 revs?
S
Things I need (Mar 08): 1990 Drivers door in calypso green for 3door - someone must have one!
Things I have found: (Mar 08)Power steering pump bracket, sun visor clip
Offline russ-vdub
« Reply #13 on: 31 March 2008, 14:35 »
it could well be, toh there could be so many reasons for this! timing, idle, co2, vac hoses, oil pressure blah blah blah...the list goes on!
Offline cняis
« Reply #14 on: 31 March 2008, 14:39 »
you forgot the blue temp sender!  :grin:
Offline cняis
« Reply #15 on: 31 March 2008, 14:40 »
when it was running, the project ran like a bag of nails with the sender connected once warm. once disconnected it purred like a kitten.
Offline lordbigsack
« Reply #16 on: 31 March 2008, 15:13 »
Sourced one locally, cheers  :smiley:
In for MOT on Weds so am crossing everything in the hope of a pass
Offline Khare
  • The bear that khares
« Reply #17 on: 31 March 2008, 15:37 »
where is the knock sensor on a 1.6 driver carb? F reg :huh:
Offline ben44
« Reply #18 on: 31 March 2008, 19:16 »
does not have one as the advance/retard is vacumn operated
My signiture sucks..........................
Offline Khare
« Reply #19 on: 31 March 2008, 20:17 »
ok cheers :smiley:
