Author Topic: Upgrading washer jets - I want more power!  (Read 2476 times)
Offline Ben Lessani
« on: 29 March 2008, 10:21 »
After driving my sisters Beetle for the past few months I have grown accustom to washer jets that actually do something. I've tried searching for ages, but without much luck.
What jets are a direct replacement, and the same rule applies for the motor.
Offline Khare
  • The bear that khares
Re: Upgrading washer jets - I want more power!
« Reply #1 on: 29 March 2008, 12:21 »
i need to fix mine, they dont spray, theres a loose connection on the steering column, and proibably need a new motor too.
Offline sesterfield
« Reply #2 on: 29 March 2008, 12:27 »
It won't increase the power of your jets, but I recommend some non-return valves from Halfords  :smiley:
Offline JMallows
« Reply #3 on: 29 March 2008, 12:32 »
I put some extra jets on mine, they fit in the bonnet vents, with a little bit of silicone, and are thus easily removable if you ever change your mind. You just need to get two extra jets, and some extra splitters from the scrap yard.
http://www.golfgtiforum.co.uk/index.php?topic=32761.msg269930#msg269930
Can get some more info if you need it?
A clever person solves a problem. A wise person avoids it.
Offline jonezee_ipswich
  • Golf Mk 2 1.8 Gti
« Reply #4 on: 29 March 2008, 21:36 »
how did you make them heated chap?
Are mk2 jets heated allready?
how did you connect the 2 extra jets just with like T pieces? diddnt that make them have less spray power?
lol sorry chap, questions questions. :laugh:
Offline JMallows
« Reply #5 on: 29 March 2008, 21:59 »
I always thought that would help, but i've tried it and it didnt help! Might have been a cheapo valve, but it did come from a Volvo...
They come heated as said from GTI's or MK3 golfs, in fact, not sure if oter models other than GTI's came with them probably GL's as well, someone will clarify..?
As for connecting them, they slot in the vent, with a little silicone (which can be removed if you change your mind) then you just get some extra hose and plug in the t-pieces
  • Golf Mk 2 1.8 Gti
« Reply #6 on: 29 March 2008, 22:28 »
looks cool mate! think im gonna give it a try!
Offline sesterfield
« Reply #7 on: 29 March 2008, 22:36 »
Well mine were pennies from Halfords but seemed to work ok!  Seemed to work better on the fronts than the rears though.
Offline Mew
« Reply #8 on: 29 March 2008, 23:13 »
Stupid question, but what do they do then??
Offline Diamond Hell
  • Opinions я Us
« Reply #9 on: 30 March 2008, 11:30 »
Non-return valves stop the water running back down the pipework, so the pump doesn't need to push it all the way up to the jets before it comes out again.
How about trying a pair of T4 jets like these:
They're like Passat B5 jets - they have a fan pattern, rather than a single jet.
There are also SAAB jets, which have three jets.
