Author Topic: MFD2 Retrofit  (Read 14181 times)
Offline joeb_444
MFD2 Retrofit
« on: 25 March 2008, 20:20 »
Hi,
I've spent the day reading all the information on retrofitting an MFD2 sat nav to a MKV Golf.  I'm confident I can fit it OK, but I have read various stories of issues following installation such as a flat battery after 3 days, door locking and fault code issues etc.  For those that have fitted the MFD2, can you confirm if it really is plug and play or does it require any coding with VAGcom?  I'm looking for some reassurance before I dive in and fit one.  Your help would be appreciated.
Joe
Offline CocoPops
Re: MFD2 Retrofit
« Reply #1 on: 25 March 2008, 20:24 »
Try posting here...
http://vwnavi.com/forums/forumdisplay.php?f=51
Its a forum dedicated to the RNS510 unit (aka MFD2)
2018 GTI Performance Pack DSG 5dr, Tornado Red, Leather, 18" Seville Wheels, DCC Suspension, Tints, RVC
2018 Lotus Elise Sport220
Previous : 1983 Mk1 Golf 1.1 & 2008 Mk5 Golf GTI Ed30
Offline winrya
Re: MFD2 Retrofit
« Reply #2 on: 25 March 2008, 20:45 »
Hi,
Joe
Mmm that worries me, i was about to treat myself but was under the impression its a straight swap and off you go?
Offline joeb_444
Re: MFD2 Retrofit
« Reply #3 on: 25 March 2008, 20:57 »
I had thought the same but became concerned after reading a few horror stories, unless they were just dodgy units?  Perhaps someone who has fitted an MFD2 could reassure me?  Thanks!
Offline isitme
Re: MFD2 Retrofit
« Reply #4 on: 25 March 2008, 21:50 »
I fitted mine and have had no problems. I had the same worries as you so bought mine from a shop though just incase the unit was faulty. But there was no problem.
With regard to the faults being logged i beleive that they commonly occur if the ignition is turned on when some of the sensors in the dash are unplugged. The on board computer logs a fault as they have something to do with the airbag  :huh:. If you follow the following you can't go wrong, I mean if i can do it anyone can  :rolleyes:
http://www.vwaudiforum.co.uk/forum/showthread.php?t=21273
hope that helps
« Last Edit: 25 March 2008, 21:53 by isitme »
Offline DaveN
Re: MFD2 Retrofit
« Reply #5 on: 25 March 2008, 22:01 »
Hi, I did my MFD2 about 10 months ago with no problems, its was a straight swap.
The http://vwnavi.com forum if great also this has all the pictures needed
http://uk-mkivs.net/forums/p/17978/170547.aspx#170547
You can use VAG-COM to change the coding from radio to navigation but I didn't until recently and saw no difference.
If you are in any way DIY then its easy.
Dave N
I think the worst time to have a heart attack is during a game of charades. Especially if your teammates are bad guessers.
Offline Spaced
Re: MFD2 Retrofit
« Reply #6 on: 25 March 2008, 22:03 »
I fitted a MFD2 DVD into my 05 GTI a few weeks ago, the friend who helped me (who works for company that deals with engine management fault codes for different garages) thought that the VAGcom might need to be told that the NAV unit was installed.
As it turns out it seemed to work fine except that I have difficulty playing audio CDs, they just stop or most of the time the unit thinks An incorrect DVD is inserted.
I am not sure if this is down to a faulty unit or some VAGcom issue (is this why they are on ebay)
I did consider sending it back, but decided it was too much hassle as I wanted to leave the NAV DVD in all the time anyway and use my ipod.
I installed a ribbon cable (half of an IDE cable) into the AUX connector so I could connect the ipod, and connected to the audio line in pins.
Also the instructions that i used and printed out ended up at the local VW dealer as they very interested too see how the swap was done (they had never done one)
Loyal owner since 2005, done with remapping, I drive a Golf not a Veyron. (hypocrite)
Offline 182_blue
Re: MFD2 Retrofit
« Reply #7 on: 25 March 2008, 22:04 »
Dave N
did u have your antenna showing like in the guide ?
Offline k4ith
Re: MFD2 Retrofit
« Reply #8 on: 25 March 2008, 22:08 »
does this give you any better options as i am considering the kenwood unit as you get bluetooth and control the ipod and can see track listings etc, where as the ipod link is shyte on the oem units, it doesn't allow you to do anything.
MKV Golf GTI Edition30, GIAC Pump&Race Map, AutoTech Fuel Pump, R32 Front Brakes, Dbilas Flo-master Intake, S3 Intercooler.ECS Dog Bone Insert.
MKII GTI 8v Tornado Red 88 - Das Projekt
Offline Spaced
Re: MFD2 Retrofit
« Reply #9 on: 25 March 2008, 22:15 »
No this option is just simply audio in via the AUX with no control from any external controls, I just simply fed a 3.5mm jack plug into the bottom of my arm rest, but you can have navigation active at the same time when you are listening. (unlike the internal CD)
