Author Topic: MFD2 Retrofit  (Read 14184 times)
Offline k4ith
Re: MFD2 Retrofit
« Reply #10 on: 25 March 2008, 22:28 »
so you cant listen to music and have the nav on ?
MKV Golf GTI Edition30, GIAC Pump&Race Map, AutoTech Fuel Pump, R32 Front Brakes, Dbilas Flo-master Intake, S3 Intercooler.ECS Dog Bone Insert.
MKII GTI 8v Tornado Red 88 - Das Projekt
Offline Spaced
Re: MFD2 Retrofit
« Reply #11 on: 25 March 2008, 22:43 »
you can listen to music via the radio/AUX Audio/CD changer (if you have one) and use the NAV at the same time, but not the internal CD player because the NAV DVD is in.
Loyal owner since 2005, done with remapping, I drive a Golf not a Veyron. (hypocrite)
Offline joeb_444
Re: MFD2 Retrofit
« Reply #12 on: 25 March 2008, 22:47 »
Thanks for all the info guys, I think I will getting one off eBay to fit myself.  Just one more question, my GTI has a standard 3.5mm aux input in the rear cupholder which I connect my ipod to - I assume this will still work with the MFD2 by just plugging in the same wiring harness?
Offline DaveN
Re: MFD2 Retrofit
« Reply #13 on: 26 March 2008, 11:15 »
did u have your antenna showing like in the guide ?
No mine was the correct type, I think its fakra or someting like that.
Dave N
I think the worst time to have a heart attack is during a game of charades. Especially if your teammates are bad guessers.
Offline joesgti
Re: MFD2 Retrofit
« Reply #14 on: 26 March 2008, 11:28 »
so why would the sat nav dvd have to be in all the time?? is this the same as all the units?? i was planning on getting this at a later date but if the DVD has to be in all the time then i wont bother.
GTI MK5
Not the only GTI...........but the best! ; )
Offline duffy78
Re: MFD2 Retrofit
« Reply #15 on: 26 March 2008, 12:05 »
dvd has to be in for the sat nav to work, its gets the map data from the dvd.
you need the 6 disc changer to listen to cd's at the same time.
Offline DaveN
Re: MFD2 Retrofit
« Reply #16 on: 26 March 2008, 12:27 »
"you need the 6 disc changer to listen to cd's at the same time"
Or an ipod adapter.
Offline The Wheel Man
Re: MFD2 Retrofit
« Reply #17 on: 26 March 2008, 12:42 »
Fitted mine about a month ago and am well impressed.  It looks better than the std unit and the sound is much better.  I have the 6 disc changer so i dont have any problems with not being able to play CD's at the same time.
I do however have my antenna on the top of the dash as i wanted the bestv possible signal.  Looks OK i think....
Reccomened  :smiley:
Offline Skidzilla
Re: MFD2 Retrofit
« Reply #18 on: 27 March 2008, 14:50 »
For a 54 plate (Jan05) GTI does it have to be the MFD2? (I assume there is only 1 version of the MFD2) :undecided:
Offline joesgti
Re: MFD2 Retrofit
« Reply #19 on: 27 March 2008, 15:07 »
was just looking on ebay and theres an MFD2 version C which it states is the newest and is able to play CDs as the mapp is built in!!!  :huh:
GTI MK5
