Author Topic: Lux Pack... re: passenger dipping mirror  (Read 2938 times)
Offline hotrod
« on: 15 March 2008, 17:04 »
Hi Guys,
Another quick question. I’ve got the Lux pack & Highline computer. The passenger mirror is set to dip when reverse is engaged (and mirror switch is set to L) and then it adjusts back to normal view when taken out of reverse.
Everythings worked perfectly well for a couple of days... however now the mirror won’t return to its normal postion unless I manually select the R position on the mirror switch (or remove the key)... it used to do it automatically.
I’ve checked the Convenience settings in the Menu & everything’s as it should be.
Any thoughts... Cheers... Hotrod
GTI Edition 30 (1783)   Candy white   KKK04 turbo
Offline block
Re: Lux Pack... re: passenger dipping mirror
« Reply #1 on: 15 March 2008, 17:09 »
Mine started doing this at times but now seems to have rectified itself, it seemed to coinside with its first service for some reason :huh:
GTI Mk7 5dr, PP, Nav, Red.
Offline carl1
« Reply #2 on: 15 March 2008, 18:52 »
mine did it.if i remember correctly had to reset been ok since, just stick it in reverse,switch mirror to L and ajust to required angle then stick it back in neutral
GTI manual PP, now sold  :-(
Offline hotrod
« Reply #3 on: 16 March 2008, 10:18 »
cheers fellas,
I’ll try resetting myself first... cheers... Hotrod
Offline hotrod
« Reply #4 on: 17 March 2008, 12:51 »
Hi tried resetting it... or just fiddling about (technical term)... still doesn’t function.
Any more clues, as it seems rather trival to travel back to the dealers for.
Cheers... Hotrod
Offline No Golf Clubs at all
« Reply #5 on: 18 March 2008, 10:11 »
(bump) mine too...anyone any ideas??? still its booked for a service next week will get it fixed under warranty.
Let the fun begin........Red Gti, full colour coding, DSG, Xenons, Winter pack, Lux pack, Highline, Sat Nav, Sunroof, Leather, Milltek, ABT rear valance, Goodyear F1 Asymmetrics....pescaras :-)
Offline hotrod
« Reply #6 on: 18 March 2008, 10:13 »
Someone on the Mark V suggested using the other key... tried that... no different!
Offline hotrod
« Reply #7 on: 20 March 2008, 17:17 »
Hi Guys,
All back to normal now, passenger mirror lens returns to normal after 10 mph.
Don’t know why... just fiddled about!
Cheers... Hotrod
Offline Manu_R32
« Reply #8 on: 20 March 2008, 17:29 »
Iv got this dipping mirrors on my R32...wheres the button, to u jsut turn the nob down?? Im sure you could set like a default to see the pavement etc then it re adjusts?
OSIR Front Splitter - OSIR Rear Diffuser - RNS 510 - JL Audio Cleansweep - JL Audio 400/4 Amplifier - JL Audio ZR650 - Recaro Bucket Seats - 3.2 V6 of Pure Power!
Offline maxamus
« Reply #9 on: 20 March 2008, 17:34 »
Lux Pack = folding in / out mirrors?
If so, ive got that but mine never dips when in reverse.....
