Author Topic: Fitting Tweeters  (Read 1988 times)
Offline daniel-1986
Fitting Tweeters
« on: 27 February 2008, 12:49 »
i am gonna fit sum tweeters into the plastic trim covering the wing mirror srews on a mk2 golf using the same technique as this http://www.talkaudio.co.uk/vbb/showthread.php?t=159311 but pointing at a 45 degree angle towards u and was wondering would it be better to use self tapping screw to put it back on or would the plastic clips hold it without falling off
Alpinehead
Re: Fitting Tweeters
« Reply #1 on: 04 March 2008, 11:03 »
i would personally pop em in the dash m8..  the hole is already there and its more stelth to keep those little chavvy eyes at bay.   :wink:
Offline Heyho
« Reply #2 on: 04 March 2008, 17:44 »
I would go with the original plan, put them on the "sail panel" on the back of the mirror - it will sound loads better.
I drilled mine, and fitted with black countersunk head screws into small plastic plugs pushed into the original mounting holes - sort of like a rawplug if you get me.  Saves them falling off.
Offline daniel-1986
« Reply #3 on: 04 March 2008, 20:08 »
i fitted them into the door cards now next to the mirror adjusters. i mite go with my original plan in the future
Offline russ-vdub
  • Once a Dub, Always a Dub
« Reply #4 on: 05 March 2008, 13:32 »
done this previously and it sound the daddy :)
Offline Jay
  • balding fat cvnt
« Reply #5 on: 06 March 2008, 23:50 »
Give us some more info russ, pic's and a write up plix  :grin:
I want to replace my front speakers, they're  :sick:
and maybe this is the way  :smiley:
