Author Topic: Quick Cam Timing Question  (Read 1135 times)
Offline Conker
« on: 22 February 2008, 22:45 »
I'm currently doing my head gasket, and while doing so noticed that the two dots on my cams are slightly off centre at TDC i.e. one is perfect, the other is slightly off. Here's a pic:
In the haynes, these are exactly in line. The question is, am I being too picky, or is the timing slightly out??
Offline rowlers
  • I'm back - MK7 GTI
Re: Quick Cam Timing Question
« Reply #1 on: 22 February 2008, 22:49 »
that looks good to me :wink:
wind the cams either way and they will line up. I've had my 16v cams one tooth out and it was way more notiecable than that!
Offline Mew
« Reply #2 on: 22 February 2008, 22:55 »
Have you removed any of the bearing caps?
Offline Conker
« Reply #3 on: 23 February 2008, 09:13 »
What are they? (Sorry... I haven't got my manual on me)
Offline rowlers
« Reply #4 on: 23 February 2008, 09:46 »
the caps with 2 bolts on each that hold the cams down.
Those cams are aligned! :wink:
Offline Conker
« Reply #5 on: 23 February 2008, 13:06 »
No I haven't removed them.
I guess its fine - Im so anal I should have been an aerospace engineer!
Offline russ-vdub
  • Once a Dub, Always a Dub
« Reply #6 on: 24 February 2008, 18:08 »
surely if you are changing the head gasket you'll have to redo the timing anyways?
Offline JC
  • Back in the North.
« Reply #7 on: 24 February 2008, 18:30 »
oy oy  :shocked: :tongue:
Offline jammac
« Reply #8 on: 24 February 2008, 20:48 »
did someone say anal?
ITS A TRAP!
Offline Dolly
« Reply #9 on: 24 February 2008, 22:15 »
if you turn them, one will go clockwise, the other clockwise... apposed to getting further apart they wll get closer.. youll find its probably a nats, if they were a tooth out it would be blindingly obvious
