Author Topic: o2a to 16v clocks  (Read 3506 times)
Offline Diluxe
o2a to 16v clocks
« on: 18 February 2008, 23:46 »
does anyone know what gear i need to get to swap my current 16v speedo cable gear thats red, to make it work in a 02a box?
cheers
1997 16V
Offline takethefifth
Re: o2a to 16v clocks
« Reply #1 on: 19 February 2008, 02:54 »
The cog is specific to the speedo, not the box.
Offline Diluxe
« Reply #2 on: 19 February 2008, 13:28 »
are you sure mate, i thought you can just whip the end of that fits into the gearbox and replace it with one that matches the gearbox, i think its something to do with the number of teeth & colour of the gear....
1997 16V
« Reply #3 on: 19 February 2008, 13:38 »
Nope i am in fact wrong!  :embarassed: Rubjonny did show me the error of my ways in the other thread.
http://www.brokevw.com/020ratios.html
Edit: After reading that I am still no wiser as to how to choose the correct gear though!
« Reply #4 on: 19 February 2008, 13:40 »
what you need is a Golf G60 or Corrado speedo cable, the MK2 one wont work at all :)
edit: apparently a MK2 1.3 speedo cable might work too?
Offline Diluxe
« Reply #5 on: 19 February 2008, 14:57 »
moved over to mk3 subframe, so have been told that mk2 1.3 speedo cable will be too short as the lump/gearbox sits lower, do you know if the G60 is longer or even what colour its gear is?
1997 16V
« Reply #6 on: 19 February 2008, 15:00 »
just thought, G60 will be LHD so no good for you, you'll need a corrado gear!  it doesn't matter what colour the G60/rado gear is, they're all the same!
I got 2 cables listed for rado, one is 1100mm the other is 1360mm.  Both discontinued :(
RHD 1.3 cable is listed at 1200mm, and G60 is 1050mm
From GSF:
76142 SPEEDOMETER CABLE  G2 1.3 Manual 8/83 >7/92  11.75
Edit: From what I've been able to find out using a MK3 subframe makes no difference to how high the engine sits, no-one has been able to say for sure (with proof) if this is true one way or the other.
« Last Edit: 19 February 2008, 15:11 by rubjonny »
Offline Diluxe
« Reply #7 on: 19 February 2008, 15:12 »
cheers mate, for reference you wouldnt happen to know what the length of the standard mk2 16v speedo cable is?
1997 16V
« Reply #8 on: 19 February 2008, 15:15 »
8v - 1720mm
16v - 1900mm
16v one is so long because it goes round the front of the inlet manifold, I've run mine along the bulkhead which should save alot of length when you come to fit it.
Offline ben44
« Reply #9 on: 19 February 2008, 19:05 »
1400 and 1600 seat toledos using the '085' box have the same connections but are slightly longer than the 1300 cable!
i stumbled across this in the scrapyard  :laugh:
My signiture sucks..........................
