Author Topic: o2a to 16v clocks  (Read 3505 times)
Offline Diluxe
Re: o2a to 16v clocks
« Reply #10 on: 20 February 2008, 10:39 »
Right just rang VW, they can get me the gear at the end of a G60 golf , so i can just use my original cable, they said i can have a red or white coloured gear one has 15 teeth, the other has 16 teeth, which one do i get? i though i read somewhere i need 13 teeth?
1997 16V
« Reply #11 on: 20 February 2008, 11:07 »
Like I said, it isnt going to work. G60 cable is totally different!  Those 2 gears are NOT for the G60 cable, they're for the std MK2 cable.
Offline Diluxe
« Reply #12 on: 20 February 2008, 11:39 »
sorry mate being a bit dense, i thought the G60 cable was to short as its LHD but i could use the gear at the end to attach to the original speedo.
Kev from 16vtrackcar.co.uk, said that his 1.3 is a tight fit & if using mk3 its unlikely to be long enough
could i attach mk2 1.3 gear to my standard 16v cable, or are you saying that the cable construction is completely different & i would be able to put any gear on my original cable that will fit in the box?
cheers
1997 16V
« Reply #13 on: 20 February 2008, 12:05 »
the issue is the fitment to the gearbox is different, so its gotta be an 02a or 085 gearbox cable, looks like the best solution would be a SEAT cable :)
Offline Diluxe
« Reply #14 on: 20 February 2008, 12:18 »
cheers for putting me right on that , would you happen to know how long a 16v 1988 passat cable is, i hear over on clubgti, that this cable works aswell, hopefully its still in production!!!! & i think they did a toledo 16v same era so hopefuly same cable.
the mk2 1.3 was dicontinued by VW at end of 07  :cry:
1997 16V
« Reply #15 on: 20 February 2008, 12:46 »
ok there are some I've found:
358 957 803 A - rhd, 16v, 1020mm - 34.41+VAT
358 957 803 G - rhd - 1450mm - 24.27+VAT
The pic looks a bit odd though, can't say for sure if the fitment is the same!
Offline Diluxe
« Reply #16 on: 20 February 2008, 17:20 »
Right spoke to a guy at seat,
he gave me two part numbers for 1.6 mk1 toledo
1LO 957 803K 1230MM
1LO 957 803L 1260MM
strangely the shorter one is more expensive than the longer one, that leads me to believe that it will the shorter one thats more appropriate fitting, anyone able to have a look if the ends look right?
1997 16V
« Reply #17 on: 20 February 2008, 17:24 »
the shorter one is for an abf so that will definitly fit your gearbox, longer one is for a 1z code lump not sure what that is, but it should still fit as the LHD ABF speedo cable is same part number as the 1Z :)
Just a case of will it fit your speedo?
Offline Diluxe
« Reply #18 on: 20 February 2008, 18:43 »
thats weird that the longer cable is also on the left hand drive car, i thought the shorter cable would be on the left drive, due to the shorter distance between pedal and gearbox............
i may have to take a punt on the shorter cable and see if it works
1997 16V
« Reply #19 on: 20 February 2008, 19:03 »
those are RHD cables, shorter one is ABF, longer is 1Z.  What i meant was the lhd part number is the same for both engine codes, so the gearbox connection must be the same :)
