Author Topic: Washer fluid warning light  (Read 7749 times)
Offline Stronz
  • Sold!
« on: 12 February 2008, 15:06 »
Ive noticed that I've been running out of window washer fluid, but haven't had a light on the dash to tell me I'm getting low. Whereabouts is the sensor for this, or is there a fuse which may have gone?
My oil light did come on the other day telling me to top up, and everything else appears to be working fine. It's just a pain, especially in these wintery conditions with all the crud on the road at the moment.
Anyone any ideas?
Cheers guys!
Offline Rhyso
Re: Washer fluid warning light
« Reply #1 on: 12 February 2008, 15:26 »
i assume its worked before?
sensor is located on the bottle itself; if you have a look there should be a hole at the bottom where the fluid comes out; think the sensor is located within that.
Offline Stronz
  • Sold!
« Reply #2 on: 12 February 2008, 15:35 »
I don't think its worked since I've had the car (Since July last year).
I'll check to see if there's a loose connection or something later on.
Offline Ridg
  • TDI - Soot Happens!
« Reply #3 on: 12 February 2008, 15:43 »
you have got the winter pack yeah?
as i thought it only came with the winter pack.
Offline Rhyso
« Reply #4 on: 12 February 2008, 16:15 »
mine don't have a winter pack and i got low level washer fluid and heated mirrors  :undecided:
Offline Stronz
  • Sold!
« Reply #5 on: 12 February 2008, 16:25 »
I dont have the winter pack - But like Rhyso I have the heated wing mirrors.
I thought a washer fluid low level warning light was pretty standard myseel. Had it in my old Escort and most other cars I've had. I'd be surprised if I dont have one!!! considering I have most over things!
Offline Ashmond
  • Money, b!tches And Boost
« Reply #6 on: 12 February 2008, 16:47 »
Mine is a base model and when I put the new clocks with the trip on it came up when the fluid was low so there is defo a sensor there as standard
Offline Ridg
« Reply #7 on: 12 February 2008, 17:59 »
i thought the fluid warning was part of the winter pack, the heated mirrors were standard on the GT TDI's and the 1.8T's i think you had to pay extra on the 2.0 GTI's though  :laugh:
Offline GTi-Matt
« Reply #8 on: 12 February 2008, 19:36 »
think it will be cheaper to buy a whole new bottle from the main stealers, i think someone has on here before and it was only £28 i think? :undecided:
I must warn you I'm about as decisive as a 5 yr old in a sweet shop!!  :grin:
Offline Rhyso
« Reply #9 on: 12 February 2008, 19:52 »
should be less; i've been quoted £18 for the larger 5.5L bottle; think the small one is £10, nit sure how much the sensor part is
