Author Topic: Washer fluid warning light  (Read 7746 times)
Offline Ridg
  • TDI - Soot Happens!
Re: Washer fluid warning light
« Reply #20 on: 13 February 2008, 09:53 »
Yeah both of my mirrors are heated.
So if my washer bottle hasn't got a sensor in it it should be a case of buying the bigger tank and swapping over? Will all the wiring be there to hook it up to?
check this bad boy out
http://bambergvr6.50megs.com/hella_washer.htm
Offline GTi-Matt
« Reply #21 on: 13 February 2008, 11:18 »
both mine are heated to, i thought the passenger side wasnt until i replaced my wing mirror cover n found the wire had come loose, so happy i had that and gave myself a big :afro:
I must warn you I'm about as decisive as a 5 yr old in a sweet shop!!  :grin:
Offline Ridg
« Reply #22 on: 13 February 2008, 11:55 »
same as.
just a theory but if you've got the mirror control selected does only that mirror get heated?
i've always thought the if it wasn't in the centre only the rear got heated
Offline Rhyso
« Reply #23 on: 13 February 2008, 12:00 »
same as.
thats right mate; has to be on the heater logo for the mirrors to be heated otherwise its just the rear screen
Offline Ridg
« Reply #24 on: 13 February 2008, 12:27 »
yeah mine doesn't have the heater logo, IIRC its just a line although they are definitely heated as had them one today and yesterday, might replace the switch at some point.
Offline AlanD
  • MK5 2.0T 16v
« Reply #25 on: 13 February 2008, 13:16 »
Do you have the black stip going throught both of them then?
Offline Ridg
« Reply #26 on: 13 February 2008, 13:21 »
WTF
do you mean line on the mirrors or the switch?
Offline AlanD
  • MK5 2.0T 16v
« Reply #27 on: 13 February 2008, 13:23 »
lol ! the line on the mirror (which I assume is the heater element). Like you we have on the rear window.
Do you have them on both mirrors?
Offline Ridg
« Reply #28 on: 13 February 2008, 13:28 »
the only line on my mirror is on the drivers side for the anti blide spot, the heating element is behind the glass so you don't see the wires (on mine anyway)
Offline AlanD
  • MK5 2.0T 16v
« Reply #29 on: 13 February 2008, 13:33 »
Oh I dunno now then, im just confussed.
Fook it !
