Author Topic: changing coolant  (Read 3465 times)
Offline kr1s77
changing coolant
« on: 08 February 2008, 07:38 »
hi all i am changing my coolant today, how long after i drain it at normal running temp should i wait before refilling it?
ASV 1.9 TDI 110
Offline oggy
Re: changing coolant
« Reply #1 on: 08 February 2008, 09:54 »
Ideally until the engine is cold, but I don't think it really matters as the expansion co-efficient of the various contact metals is not that great given the temperature difference at operating temp. ie there is not much danger of snapping head bolts or similar. Make sure you flush the block and heater matrix out too - not just the radiator - and top up after a run if required. Do not run the engine whilst draining either!
Offline kr1s77
« Reply #2 on: 08 February 2008, 11:16 »
how do i drain the block and heater matrix
ASV 1.9 TDI 110
Offline oggy
« Reply #3 on: 08 February 2008, 11:32 »
undo connecting inlet/outlet pipes. Hose in at one end, drain at other
Offline Mikester
  • Civic Type R
« Reply #4 on: 08 February 2008, 22:48 »
Engine is cold, take of bottom rad hose, empty out. Hook back up with NEW jubilee clips, and refil. start engine until rad turns on. Top up. AS the system will need more water once rad has turned on when it gets to mid temp.
Offline kr1s77
« Reply #5 on: 09 February 2008, 20:09 »
thanks for the help, i done it today  :smiley:. i changed the coolant temp sensor aswell and it cured my over revving problem aswel  :laugh:. my car now idles great at 800 - 840 and has new g12+ coolant.
well chuffed  :grin:
ASV 1.9 TDI 110
Offline Mikester
  • Civic Type R
« Reply #6 on: 09 February 2008, 21:38 »
Nice one, hope it makes problem free motoring, until the next Vdub problem, lol  :laugh:
Offline Pete Taylor
« Reply #7 on: 10 February 2008, 07:32 »
You'll find that you will want to buy a new coolant bottle too to make it look good lol
Offline Mikester
  • Civic Type R
« Reply #8 on: 10 February 2008, 17:09 »
I want too do that, lol!
