Golf mk3
hardmonkeys
changing coolant
Topic: changing coolant (Read 3460 times)
kr1s77
Here all the time
changing coolant
08 February 2008, 07:38 »
hi all i am changing my coolant today, how long after i drain it at normal running temp should i wait before refilling it?
ASV 1.9 TDI 110
oggy
GTI forum regular
Re: changing coolant
08 February 2008, 09:54 »
Ideally until the engine is cold, but I don't think it really matters as the expansion co-efficient of the various contact metals is not that great given the temperature difference at operating temp. ie there is not much danger of snapping head bolts or similar. Make sure you flush the block and heater matrix out too - not just the radiator - and top up after a run if required. Do not run the engine whilst draining either!
kr1s77
Here all the time
08 February 2008, 11:16 »
how do i drain the block and heater matrix
ASV 1.9 TDI 110
oggy
GTI forum regular
08 February 2008, 11:32 »
undo connecting inlet/outlet pipes. Hose in at one end, drain at other
Mikester
Forum addict
Civic Type R
08 February 2008, 22:48 »
Engine is cold, take of bottom rad hose, empty out. Hook back up with NEW jubilee clips, and refil. start engine until rad turns on. Top up. AS the system will need more water once rad has turned on when it gets to mid temp.
kr1s77
Here all the time
09 February 2008, 20:09 »
thanks for the help, i done it today
. i changed the coolant temp sensor aswell and it cured my over revving problem aswel
. my car now idles great at 800 - 840 and has new g12+ coolant.
well chuffed
ASV 1.9 TDI 110
Mikester
Forum addict
Civic Type R
Reply #6 on:
09 February 2008, 21:38 »
Nice one, hope it makes problem free motoring, until the next Vdub problem, lol
Pete Taylor
Reply #7 on:
10 February 2008, 07:32 »
You'll find that you will want to buy a new coolant bottle too to make it look good lol
Mikester
Forum addict
Civic Type R
Reply #8 on:
10 February 2008, 17:09 »
Quote from: Pete Taylor on 10 February 2008, 07:32
I want too do that, lol!
Pete Taylor
Reply #9 on:
10 February 2008, 17:12 »
http://cgi.ebay.com/ebaymotors/VW-Golf-Bora-Jetta-MK4-Coolant-Expansion-Tank-Brand-NEW_W0QQcmdZViewItemQQ_trksidZp1638Q2em122QQcategoryZ46096QQihZ017QQitemZ270209039070QQrdZ1QQsspagenameZWD2V
Golf mk3
hardmonkeys
changing coolant
