Author Topic: mk3 calipers on mk2?  (Read 3253 times)
Offline Maltloaf
« on: 30 March 2004, 09:34 »
Hi all,
I have a GTI 8v and the rear calipers hand brake mechanism keeps sticking on. I am sure that I have heard that the mk3 calipers fit and do not have this problem. I tried searching the forum archive but could not find anything.
Short of stripping it down and rebuilding it is there a better replacement?
Thanks
Matt B.
« Last Edit: 30 March 2004, 09:35 by Maltloaf »
Offline Gambit
« Last Edit: 30 March 2004, 09:41 by Gambit »
Offline davidhawkins_78
  • Valver Bad Boy
Re:mk3 calipers on mk2?
« Reply #2 on: 30 March 2004, 09:42 »
Done the very same thing to my GTI with the help of Vr6  (or should I say watched him do it ..)
Providing you have a certain letter in your chassis number they're a straight swap. Your car has to have left the factory after '88, but I can't remember the letter ... Vr6 you out there to confirm??
Also make sure you get the late spec Mk3 calipers as the earlier one are the same as Mk2 one's !!
Hope this helps ...
ps. Mk4's fit too but you'll need a different brake line - only difference is they're alloy...
'89 Monza Blue Valver
to quote a VW engineer, "the Mk1 was the prototype, the Mk2, the real thing!"
Offline Maltloaf
« Reply #3 on: 30 March 2004, 09:42 »
Cheers guys.
My car is a 1991 H plate. So I think it should be good to go. Any idea of the part number(s)?
« Last Edit: 30 March 2004, 09:44 by Maltloaf »
  • Valver Bad Boy
« Reply #4 on: 30 March 2004, 09:48 »
Mine where from Lucas .. really not sure on the part number I'm afraid.
VeeDubGTI16v
« Reply #5 on: 30 March 2004, 10:10 »
is it just the handbrake cable that is better?
Offline Gambit
« Reply #6 on: 30 March 2004, 10:13 »
no, the handbrake mechanism on mk3 calipers is internal, therefore doesnt seize
mk2 is external and seizes if not greased up every so often
if you have a pre89 car then its just a case of getting post 89 handbrake cables if you want to run mk3 calipers
VeeDubGTI16v
« Reply #7 on: 30 March 2004, 10:15 »
sorry thats wot i mean. there not radically better brakes as in stopping power
Offline Gambit
« Reply #8 on: 30 March 2004, 10:16 »
nah no difference in stopping power - rears only contribute about 25% of overall stopping power anyhow
golfvr6
« Reply #9 on: 30 March 2004, 10:41 »
I think if the 10th letter of your chassis is K onwards then mk3 calipers will fit straight on. What is the letter on yours Dave?
ETKA states late 88 was when the later mk2 calipers were first fitted, so might be able to use mk3 calipers on a late 88 as well.
Check Dave's gallery (if he still has the pic on), if your calipers have the handbrake coming up underneath then mk3 calipers will be a straight swap.
