Author Topic: mk3 calipers on mk2?  (Read 3254 times)
Offline Dizzie
  • Make friends with your fast
Re:mk3 calipers on mk2?
« Reply #10 on: 30 March 2004, 10:49 »
so if I wanted to fit them I'd have to change the cable too?
mine's D plate
I have to change the cable soon anyway.
golfvr6
« Reply #11 on: 30 March 2004, 10:53 »
How is the handbrake routed on yours?
Offline davidhawkins_78
  • Valver Bad Boy
« Reply #12 on: 30 March 2004, 11:04 »
Hello Vr6 ... just stuck the pictures back up so feel free to have a butchers Maltloaf ....
'89 Monza Blue Valver
to quote a VW engineer, "the Mk1 was the prototype, the Mk2, the real thing!"
golfvr6
« Reply #13 on: 30 March 2004, 11:06 »
Alright mate, hows it goin?
hows those brakes now?
  • Valver Bad Boy
« Reply #14 on: 30 March 2004, 11:10 »
Sweet as a nut after plenty of bleeding - definately much better with the older bleed nipples so might be and idea to remind these guys !!!
!! IF YOU CHANGE YOUR CALIPERS USE THE OLD NIPPLES OR YOU CAN'T BLLED THE SYSTEM PROPERLY !!!
golfvr6
« Reply #15 on: 30 March 2004, 11:17 »
Certain Mk3 calipers seem to have the wrong bleed nipples, as in the taper is wrong.
What happens is you need to open the nipple out too far to get fluid out, this seem to trap an air bubble around the outside of the bleed nipple.
So if anyone has this problem, calipers seem to bleed constant air, then change the bleed nipples over for the old ones.
Blue MK2
« Reply #16 on: 30 March 2004, 16:16 »
^ think thats a top tip VR.
ill keep that in mind
Offline Dizzie
« Reply #17 on: 30 March 2004, 19:54 »
my handbrake attaches to the top if that's what you mean. I think it does anyway. Will look soon.
