Author Topic: forge spliter dv  (Read 5135 times)
Offline leeroy20vt
  • h reg mk2 gti
forge spliter dv
« on: 06 January 2008, 16:00 »
just fitted 1 to my car all good looks good drives better seems to have a bit more go in it
any way u can hear the ppppppsssssssttttt wne u rev it not in gear but wen i drive it it dont make any noise
any ideas ???
lee
Offline richw911
Re: forge spliter dv
« Reply #1 on: 06 January 2008, 16:12 »
Is your car standard? Could be Lack of boost, A remap and a carbonio air intake would help. Dont know too much about these spliter dv's tho.  :undecided:
Offline leeroy20vt
  • h reg mk2 gti
« Reply #2 on: 06 January 2008, 16:28 »
standard m8 didnt but it for the noice really but it was cheap and of a local so thought i would get it plus cant really go wrong with a upgrade from the plastic 1 just wierd it really loud wen not driving it
car feels better tho got a bit more get up and go
cheers rich
Offline silveradobullet
  • 'Mr. Green, You Are in Danger..... Take the Stairs
« Reply #3 on: 06 January 2008, 16:59 »
if its recirculating, you wont get the"ptshhhh" sound. it will run alot better as there is not restriction like on the bosch plastic valve.....
does it hold its boost properly when you florr it in 5th, at about 110mph?
Offline richw911
« Reply #4 on: 06 January 2008, 17:08 »
Its a forge splitter dv it dumps some air into the atmosphere and some back into the system.
Offline ian00uk
« Reply #5 on: 06 January 2008, 17:08 »
ive got 1 of these but mine is remapped and it doesnt make any noice wen not in gear but does whhssss wen driving.have u tried adjusting the screw bit at the end. this lets the release hole get bigger or smaller depending how much air u want to let go for the sound?
Offline leeroy20vt
  • h reg mk2 gti
« Reply #6 on: 06 January 2008, 17:41 »
acoording to forge u cant adjust the sound the adjuster is how hard the spring is set inside u adjust this to get it to hold the boost properly apparently i have moved it about and test drove it but if u got to far  way the car dosent seem to pull properly
Offline ian00uk
« Reply #7 on: 06 January 2008, 20:13 »
u have got the right spring in there havent you as theres different colours for different boosts?
« Reply #8 on: 06 January 2008, 20:18 »
hmmmmm.... ive heard about these split valves, but never really understood....... ive got an HKS SSQV on mine, which is a Atmospheric, but i have pipework to turn it into a recirc when i want to....
when it is recirculating, it makes a wicked sound still, but even when its atmospheric, the myth about it messing up is complete rubbish! it just makes your car run richer thats all, but all turbo cars run rich --- thats a legend!
in my opinion, i feel that split DV's are overated and well.... pointless...... you either want it going in, or going out..... a split just causes confusion~! lol!  :smiley:
Offline richw911
« Reply #9 on: 06 January 2008, 20:44 »
  Its not complete rubbish!! I quote from forgemotorsport :
"  The Splitter is a truly remarkable valve that gives a combination of blow off and recirculation valve operation all at the same time and has been specifically designed for the many VAG 1.8T applications. This means you get all the noise of the blow off valve whilst retaining the compatibility with the recirculation requirements of the engine management system "
It may not always throw on a light on the dash but you engine Will not run correctly with an atmospheric dv.
 Ask any one on here its been proved time and time again!!  :tongue:
