Author Topic: forge spliter dv  (Read 5138 times)
Offline leeroy20vt
  • h reg mk2 gti
Re: forge spliter dv
« Reply #10 on: 06 January 2008, 21:05 »
rich exactly y i went for a forge because most on here said the the best and most suited for the car as i toyed with just chuckin a normal dv at it but then i rather my car run properly than run the risk of killing something if not now maybe a few months down the line
i mean how many people have said dont put a normal dv on the 1.8t engine hhhmmmmmmmm me thinks theres a reason for this dont u
And for what i paid for i cant compain  :laugh:
Idont know what spring it has in it i would defo say it has the original 1 that it comes with it thats an help
Offline richw911
« Reply #11 on: 06 January 2008, 21:09 »
Exactly mate you hit the nail on the head!!!
Offline silveradobullet
  • 'Mr. Green, You Are in Danger..... Take the Stairs
« Reply #12 on: 06 January 2008, 21:11 »
can i say that that quote you got is very good P.R and great advertising gismo..... thers been a thread before about it i think? but anyway, in regards to correct functioning (lol) VAG have gone something really wrong somewhere..... as alot of turbo cars do.....
every turbo car comes with a recirc dump valve..... these are placed in because they are there simply to ruin your turbo.... its so the drivers have to buy consumables i.e a new turbo every year..... when they recirc, they force air more back into the turbo the wrong way, causing it to stall, lag, chatter and spin the WRONG way for a second or two.... this puts loadsa force on the turbine itself and even the housing, causing whichever to crack first......
i completely agree that it makes it run not as it should, as everything in modern cars is controlled by electronics etc....  but its only telling the engine is hasnt got enough air making it componsate for it with petrol! lol! so therefore runs rich and spits flames like a jet! this can be overcome buy fitting a CAI..... i think? BSC Hons Automotive design, thats what they taught me!
i dont want 2 offend anyone, but the myth id say is Boll*x..... if anything will break it'll be a sensor...... me thinks?
Offline leeroy20vt
  • h reg mk2 gti
« Reply #13 on: 06 January 2008, 21:21 »
every 1 to there own and i dout u affenede any 1 lol i just think that wen u read god knows how many threads sayin a normal dv is not good that sways me slighty to puttin the rite parts on the car  but hay what works for may have not worked for me but will prob work for others  is ur car mapped sivleradobullet
or standard and have u just caped the air box side of the dv off
« Reply #14 on: 06 January 2008, 21:30 »
well i was in the same situation when i bought mine, didnt know what DV 2 go 2 , but asked a few of my mechanic mates and they said it was rubbish, and i believe it now....
on the metal pipe for the turbo, ive welded on the HKS DV and the rubber pipe which extends (normally) to the bottom of a DV is the pipewrok which recirculates back into the intake...... its a good setup!
it aint mapped (yet) and im running a Carbon Fibre K&N CAI, sounds beautiful.....
i guess its good 2 have it recirculated if there is a chance of it going wrong, id say its down to something else.... newer engines arnt toys and alot of people tinker with them and dont have a clue..... not saying you dont, just sayin there are other reasons for them to fail... :smiley:
Offline leeroy20vt
  • h reg mk2 gti
« Reply #15 on: 06 January 2008, 21:41 »
tbh m8 i have no fookin clue about these engines well turbos and the way they work to be exact altho i culd do most mechanical jobs my dad is a mechanic for god knows how many years and a mot tester  but he not to keen on workin on turbos either thats y i been listenin to what other people have said lol
its all good fun and a learning curve tho
« Reply #16 on: 06 January 2008, 21:46 »
just rememeber..... "if it boost's into red, ya turbo's dead!" lol!  :grin:
Offline leeroy20vt
  • h reg mk2 gti
« Reply #17 on: 06 January 2008, 22:04 »
lol
how do i know if it in the red my boost gauge aint got colours lol
Offline richw911
« Reply #18 on: 06 January 2008, 22:11 »
Well it depends on which 1.8T engine you have.
The early ones IE: AGU (Non drive by wire) dont have a map sensor (http://autorepair.about.com/cs/generalinfo/l/bldef_495.htm) so you can get away with it to some extent.
Later one IE: AUM/AUQ Drive by wire DO have map sensors and Will go into limp mode and f*** up the MAF!!!
I think the forge 007p gives a nice sound which can be heard in the car a tiny bit and not outside. Its not too loud and OTT. But each to your own if eveyone was the same the world would be a boring place!
« Last Edit: 06 January 2008, 22:18 by richw911 »
Offline leeroy20vt
  • h reg mk2 gti
« Reply #19 on: 06 January 2008, 22:22 »
rich do u rember i put a post up about a fluttering noise well since i changed the dv it dont do it any more
also this split dv is well lound wen u rev it hard wen not in gear but cant hear it at all wen u driving it well weird
