Author Topic: Running like a bag of nails ... sometimes  (Read 1971 times)
Offline mk2mark
« on: 04 September 2007, 18:41 »
Hi,
I've mentioned this before but it's been steadily getting worse, however I think I have come across something unusual when I was topping up with oil. Is it normal for the car to cut out when you've the oil filler cap off? What happens with the car is it randomly runs from bad to worse to running beautifully and it's wrecking my head because I know as soon as I take it to someone it'll run fine :laugh:
:cry:
Help me please!
Offline Simpson
  • one day il learn
Re: Running like a bag of nails ... sometimes
« Reply #1 on: 04 September 2007, 23:07 »
check your breather are not blocked mine does that now and then, , does it burn oil?
i must buy a new car!
Offline Davo13
« Reply #2 on: 04 September 2007, 23:15 »
Have you tried cleaning all the hoses.  It sounds as if there is a blockage seen as it breathes on its own when you take the oil filler cap off.
Offline mk2mark
« Reply #3 on: 05 September 2007, 10:17 »
I presume you mean the breather being the flying saucer thing on the rocker cover. I presume you unblock it with a little petrol or something? Makes some sense I suppose, although I replaced it not too long ago. Also I would have thought the oil the car burns is normal for something 16 years old, it's not a huge amount anyway.
Davo not sure which hoses you mean tbh :smiley:
« Reply #4 on: 07 September 2007, 13:24 »
yes, you're making a big airleak if you take the cap off, so dont be surprised it it runs funny or cuts out ;)
digifant tuning guide ;)
Offline Simpson
  • one day il learn
« Reply #5 on: 07 September 2007, 21:47 »
that bloody digifant tuning guide is that the answer to everything  :grin: just kidding
Offline Ben Lessani
« Reply #6 on: 08 September 2007, 07:27 »
After I rebuilt the head on my mums 206 for the first 20 miles or so, it would run dodgy with the oil cap off, and noisey! I wouldn't be massively concerned, as long as it runs fine with the cap on  :wink:
Offline mk2mark
« Reply #7 on: 08 September 2007, 22:57 »
Ok update, the car's running great apart from when it idles. Think it's the flying saucer thing again - the thing is when it idles (choppily), it's blowing oil out of the rocker cover gasket. Any ideas?
Offline Ben Lessani
« Reply #8 on: 08 September 2007, 23:44 »
If its blowing oil out then replace it?
« Reply #9 on: 09 September 2007, 12:15 »
could be the pcv is blocked and causing excess pressure in the crankcase & blowin it out the rocker seal.  but 1st thing to do is replace the seal!
