Author Topic: Running like a bag of nails ... sometimes  (Read 1967 times)
Offline Davo13
Re: Running like a bag of nails ... sometimes
« Reply #10 on: 09 September 2007, 12:58 »
I presume you mean the breather being the flying saucer thing on the rocker cover. I presume you unblock it with a little petrol or something? Makes some sense I suppose, although I replaced it not too long ago. Also I would have thought the oil the car burns is normal for something 16 years old, it's not a huge amount anyway.
Davo not sure which hoses you mean tbh :smiley:
Perhaps a little late replying.  The hoses I am talking about are the ones that come from the "flying saucer thing" and the ISV, which all lead to the Throttle Body and the air intake hose.  Also clean the flying saucer itself.
The rocker gasket is an easy job, may as well change it.
Offline mk2mark
« Reply #11 on: 10 September 2007, 14:03 »
1st thing I did was change the rocker cover gasket :laugh: if anything it's worse than before :sad: Checked the PCV too, it's possible that it's not working considering the idle, but I doubt it's blocked, I can easily blow air through it both ways.
« Reply #12 on: 10 September 2007, 15:07 »
did you swap the old cork gasket for the newer rubber type, and if so did you swap to the late shoulder-less studs?
Offline mk2mark
« Reply #13 on: 10 September 2007, 20:41 »
Well it's a pretty corky gasket, came from gsf - it's a 91 car so I assume it has the right bolts anyway?
Forgot to say all the help so far is much appreciated :smiley:
Offline Simpson
  • one day il learn
« Reply #14 on: 10 September 2007, 21:06 »
nah it wont have unless its alreayd had a rubber one fitted they dont have a shank on the bottom, the ones for cork and standard do. I think you have to order a mark 3 one or they get confused at Vw  :smiley:
i must buy a new car!
« Reply #15 on: 10 September 2007, 21:23 »
A 91 might have had a rubber gasket from the factory, only way to check is to take the rocker cover off and check the studs.  If they have a shoulder you need a cork gasket, if they dont you need a rubber one.  The shoulder is there to prevent you from overtightening the cork gasket see.
Offline mk2mark
« Reply #16 on: 11 September 2007, 17:15 »
Cool thanks lads, i'll take a closer look at which gasket I got and get a new PCV (from vw this time) and see if that fixes things - fingers crossed!
Offline DarnPB
  • Formerly Darnpistonbroke
« Reply #17 on: 12 September 2007, 17:18 »
Just a thought and I hate to bring up what could be bad news, but remove the intake duct, the one that goes from the air filter housing to the throttle body, and look inside the throttle body for excessive oil. You may be getting crankcase compression, thus blowing oil straight into the injection system. If the throttle body is dripping wet, get a compression check done.
Offline mk2mark
« Reply #18 on: 14 September 2007, 00:10 »
Thanks I will.
