Author Topic: Which AMP?  (Read 4490 times)
Offline Snap
  • Just smile, stop being miserable!! :-)
Which AMP?
« on: 25 August 2007, 23:52 »
I bought a sub from a fellow forum member and now i need an amp to accompany the sub. The sub's output is 1200W so what do i kinda amp do i need?
Ta.
'92 1.8 Mk2 Golf, carbed GU... [SOLD]
Offline davy80
Re: Which AMP?
« Reply #1 on: 28 August 2007, 12:06 »
an 800w to a 1000w amp would do the job, im runnin 2 12" subs which are 800 w each and they sound fantastic. i got a sony explode 1000w amp for around £200. get a good wiring kit, spend about 30 to 50 quid on them cause they make all the difference and run your power cable down one side of the car and the resr down the other to avoid distortion. hope this helps.
Offline Heyho
Re: Which AMP?
« Reply #2 on: 28 August 2007, 21:28 »
Better off telling us what make/model the sub is really - those power figures don't mean a great deal in reality.
Also depends upon how you'll be running the sub - sealed subs can take a fair whack more power to get them going.  I've had my "1000w" GT4 (ported) singing well from a genuine 140w RMS.
Offline Snap
Re: Which AMP?
« Reply #3 on: 29 August 2007, 00:41 »
I dont know much about car audio, all i know its a 12" Sony Xplod sub in a wooden box, it says 1200W max output on the speaker. Any ideas?
Offline tommk3cab
Re: Which AMP?
« Reply #4 on: 29 August 2007, 12:15 »
ah, old school jensen amps, lovely!
I suspect the sub to be about 350-400wrms.
so any amp about that value should be good for it. JBL are always a safe bet, or fusion.
Offline Snap
Re: Which AMP?
« Reply #5 on: 29 August 2007, 13:32 »
I'll get the speaker out of the enclosure and have a look at the back so i can get a some more info hopefully.
Offline Snap
Re: Which AMP?
« Reply #6 on: 30 August 2007, 03:19 »
I looked at the back of the sub and it says:
Frequncy response: 18Hz - 2000Hz
Rated power: 350W
Impedance: 4 Ohms
Peak Power: 1200W
Here's more info after a web search:
http://www.sony.co.uk/view/ShowProduct.action?product=XS-L121P5S&site=odw_en_GB&pageType=TechnicalSpecs&imageType=Main&category=ICA+Subwoofers#tab
So should i be looking for an amp thats rated 350W? What else should i want from the amp?
Ta.
Offline Heyho
Re: Which AMP?
« Reply #7 on: 30 August 2007, 21:32 »
Why not just try the Jensen with 2 channels bridged?  You've got nothing to lose - might be 200w RMS if you're lucky, and should get the old X-plop moving.
Offline vr4000d
Re: Which AMP?
« Reply #8 on: 30 August 2007, 21:35 »
Offline Snap
Re: Which AMP?
« Reply #9 on: 31 August 2007, 02:24 »
The jensen amp was sold seperately.  :sad:
