Author Topic: Save or Scrap! 5 Door 8 Valve  (Read 2360 times)
Offline WhiteMk2Gti
« on: 13 June 2007, 17:23 »
 :undecided:
So it went for its MOT today and 18 things wrong later:
Both rear lamps rear position lamps adversely affected by the operation of another lamp (?)
Nearside rear brake caliper braking system leaking (it needs tighting up)
Nearside front brake pipe on inner wing braking system leaking
Brake Hydraulic reserviour fluid level below minimum level (should of checked)
Exhaust system noise is clearly in excess of that emitted by a similar vehicle fitted with a standard silencer in average condition (hey ho)
Nearside rear exhaust system mounting missing (i gather thats a rubber then)
Nearside rear wheel bearig feels rough when rotated (wheel bearing knackered)
Nearside inner rear brake hose ferrule excessively corroded
Nearside rear brake cable tyre fouling a part of the vehicle (pipe rubs tyre)
Both front wishbone rear bushes suspension arm rubber bush deteriorated resulting in excessive movement
Offside front anti-roll bar linkage rubber mounting deteriorated resulting in excessive movement
Nearside outer front, bush missing, anti-roll bar linkage has excessive play in a pin/bush
Offside macpherson strut upper support bearing is rough in operation (new dampers and coils fitted under 6months ago)
both rear axle bushes trailing arm rubber bush deteriorated resulting in excessive movement
Parking brake efficiency below requirements (9%)
Advisory Item
Steering system has slight free play detected at steering wheel
No rear seats fitted
Front grill adrift (?)
So, what cost would that be?
Worth keeping or scrap and buy another?
You know you want to, you dont realise it yet!
Offline HARDCOR3
Re: Save or Scrap! 5 Door 8 Valve
« Reply #1 on: 13 June 2007, 17:34 »
seems a bit heavy handed on some of the fails, but if it's a clean car with bits done, it's worth doing, if it's just your average run of the mill 5dr, use it as an excuse to buy a 3dr.... :wink:
Offline WhiteMk2Gti
« Reply #2 on: 13 June 2007, 17:36 »
Does seem heavy handed (after i had just done a really nice job waxing his car) but new calipers all round, new discs, pads, handbrake cables, dampers, coils, full service (4 months ago) in fact over £1,000 spent in the last 12 months, but if it costs more to fix than buy another.........................
Offline HARDCOR3
« Reply #3 on: 13 June 2007, 17:42 »
buy a 3dr n rob all yer new bits... :afro:
Offline WhiteMk2Gti
« Reply #4 on: 13 June 2007, 17:45 »
It has MOT?
Driveable?
If so PM
« Last Edit: 13 June 2007, 17:48 by WhiteMk2Gti »
Offline cняis
« Reply #5 on: 13 June 2007, 18:31 »
Sounds mainly like consumable parts... get it fixed  :smiley:
Offline Bluefox
  • ...back again!
« Reply #6 on: 14 June 2007, 00:08 »
I'd fix it. Unless it's atlas grey, in which case I'll have it. :laugh:
Bluefox
Current: '84 Golf C 1.9 TDi | '01 Polo GTI | '01 Audi A2 TDi | '83 MG Metro
Previous: '83 GX | '04 R32 | '93 VR6 | '86 GTi 8v | '88 Diesel | '92 G60 | '04 Skoda Superb TDi | '90 GTi 8v | Plus many more!
Project Thread - http://www.golfgtiforum.co.uk/index.php?topic=270683.0
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
« Reply #7 on: 14 June 2007, 00:23 »
fix.
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
Offline OakeyDoak16v
« Reply #8 on: 14 June 2007, 01:16 »
Fix it! I had similar probs with mine on last MOT (Bushes, calipers, steering stuff) It was quite a lot really and cost £300 quid. Money well spent i say as it drives a hell of a lot better. You wont get another car for that money and some one is only going to offer you a few quid with no MOT.
Offline moonsta
« Reply #9 on: 14 June 2007, 20:41 »
 FIX IT................. if you buy another you will probably end up doing the same sort of jobs on that one too, least there done for a couple of years at least......
Drives '96 Polo 6N and '85 Mk Golf Gti...
