Author Topic: Len's Mk3 16v ~ The Rebel Car! New Wheel Pics Page 90  (Read 610218 times)
Offline Len
Re: Len's Mk3 16v ~ The Rebel Car! New Front Pics Page 75
« Reply #910 on: 19 June 2013, 13:00 »
Well Brad I knew what the costs were before I started, well the overall cost anyway.
I can understand now why I was quoted 3 grand to do it!
www.sas.org.uk
www.the-ace.org.uk
Offline tshirt2k
  • Been there...Done that...
« Reply #911 on: 19 June 2013, 21:52 »
It doesn't have to be expensive. What is the spec your aiming for?
Mk3 ABF 16VT Megasquirt V3
Offline Len
« Reply #912 on: 20 June 2013, 12:57 »
Having trouble finding normal pistons 83.5mm bore. Found forged ones at over £600 a set.
With costs like that it soon adds up!
Then a tube exhaust manifold
Head and cams
ITB's
etc. etc.
www.sas.org.uk
www.the-ace.org.uk
« Reply #913 on: 20 June 2013, 13:32 »
Might be worth trying Karl Schmidt: http://www.elringparts.co.uk/products/ks/ unless you have already
Offline tshirt2k
« Reply #914 on: 20 June 2013, 22:02 »
If you're planning that its gonna cost ya. Alot ££/hp you can still get good results with standard pistons and rods. Also if you are using lumpy cams, emissions will be an issue on a mk3.
Offline Len
« Reply #915 on: 21 June 2013, 09:37 »
Nope! Duff info! They dont do any pistons for the 16v abf engine.
www.sas.org.uk
www.the-ace.org.uk
Offline Len
« Reply #916 on: 21 June 2013, 09:41 »
I know its gonna cost!
I have had issues with emmissions for the last 4 years but those have been overcome! (I changed MOT station!) :wink:
Not going for real lumpy cams, extended duration with a little extra lift.
www.sas.org.uk
www.the-ace.org.uk
Offline Metallix
« Reply #917 on: 21 June 2013, 11:40 »
No but I might use an economy mode.
Just not convinced your Megasquirt one is for me.
It probably isn't if you're not that way inclined.
You don't need switcable maps just for economy on a SEM because you can map the cruise areas to give you best economy if you like.
You can adjust fuel to run leaner at light cruise at 50,60 or 70mph but be richer in power areas when you put your foot down.
tshirt2k gave good advice here.
With alpha/N for throttle bodies   the high TPS regions e.g. 60% to 85%+ deal with high load / WOT.
Low TPS values are part load / cruising.
This is the same on a speed density system using a MAP sensor, but the TPS value is replaced by MAP.
The only reason to have switchable maps IMO is for 95RON & Super unleaded 97/98/99RON
Offline Len
« Reply #918 on: 21 June 2013, 12:33 »
You see I have no idea wtf you are on about!
So I am going to plug into the ECU and play with such things?
www.sas.org.uk
www.the-ace.org.uk
Offline tshirt2k
« Reply #919 on: 21 June 2013, 13:25 »
Exactly why you should do some research on forums where there is lots of info on such things.
You need to know the effect of what you are planning. Then decide if its worth the cost.
You also need to know what CR you want to run and how you are going to achieve it. Skimming head, block, or getting pistons. Each will have different costings.
I wouldn't be undertaking such a job and have no knowledge/idea of what it entails.
IMO You need to know wtf he is on about or you will be throwing money down the drain.
As I've said before, you can get 175ish hp from decent mapping on a standard block and head.
Save yourself hassle and money by changing crank and machine pistons to give ~11.2:1
You couldn't go wrong by contactinh Hotgolf. I think he is on here. He has built a few and knows alot on this whether it'll be new pistons or not.
Re emissions. Have you not thought about fixing the problem? because an engine in good order should pass fine.
