Author Topic: fully de-locked ..... what do you do if the bat goes dead?  (Read 2585 times)
Offline BobbyT
well i know its a pritty obvious question i guess the only way is to smash the glass to get to the bonnet release, but as i have already delocked the doors and i may be buying a fully smooth tail gate are there any other options than this? not sure if its worth just getting my tail gate half smoothed like the badges and wiper hole and leaving the lock?  :undecided:
« Last Edit: 24 February 2007, 10:33 by Toofunkyhouse »
Offline Madone_si
  • Seattle WA, USA and Middlesex, UK
Re: fully de-locked ..... what do you do if the bat goes dead?
« Reply #1 on: 24 February 2007, 21:28 »
Do what the guys do with large stereo in cars, add an additional battery, which will act as secondary battery if main one does die. :)
Old Skool Mk1 Golf Gli (82), Mk1 US Cab 85 and 83
SOLD - BLACK SOY 92
Offline M41K1T
« Reply #2 on: 26 February 2007, 11:46 »
I have smoothed doors but stilll need to fit door pops, what solenoids are you useing or can you recommend any?
« Reply #3 on: 26 February 2007, 11:49 »
you could fit 2 wires to the battery terminals, and have them dangling down near the chassis leg.  Obviously secure them and cover the bare ends, then if the battery dies get underneath, peel back the covering and connect your jump leads :)
or if you can reach, connect the red jump lead to the starter motor +ve, and the black one to somewhere on the chassis ;)
Offline BobbyT
« Reply #4 on: 26 February 2007, 11:52 »
thats not a bad idea mate! i suppose i could use some amp power leads and then just run them to the back, are there no issues with doing this?  :undecided:
Offline BobbyT
« Reply #5 on: 26 February 2007, 11:56 »
hi mate, sorry but i have only delocked it, i stull have handles to pop the doors, only now i have central locking which works off the key fob, not sure what type of solenoids i have as i had this all done when i got my cat 1 alarm fitted. I  just told them i wanted central locking and they did the job!  :smiley:
Offline M41K1T
« Reply #6 on: 26 February 2007, 11:58 »
i c
nice 1
« Reply #7 on: 26 February 2007, 12:04 »
the only issue would be if you allowed the +ve terminal to short on something ;)
Any live wire will do, for example you can get car jumstart kits which plug into the cigarette lighter of both vehicles.  Can't say I'd be too happy running starter ampage through the cigarette lighters though  :shocked:
Offline Stu.750
  • MMMMMMM Rust my favourite
« Reply #8 on: 27 February 2007, 12:51 »
 You could use Anderson sockets , Some Race cars use them as a jumper and they trucks i used to work on did , have one end attached under the car , other with some crocodile style ends and the male part of the anderson socket
Offline theruler
smashy smashy
