Author Topic: No life in the old girl after I've refitted the head  (Read 3704 times)
Offline jaybv6
  • 03 Mk4 GTTDI PD 150
« on: 17 February 2007, 22:48 »
Car - 88 GTi 8v PB
I finally got round to starting up my Golf today except that it won't.  All leads and earths are in place.  Removed the coil lead to the dizzy and cranked it over a few times to build up some oil pressure.  I then reconnected the Coil lead to the Dizzy and fired up the car.  It cranks over but no joy in starting.  Removed a spark plug and cranked it over, there is a spark.
Have checked the timing and all is ok.  Removed the inlet fuel hose and cranked it over, pump primes and fuel comes out of the hose.  I drained the fuel from the tank as it was stale.  Replaced fuel with the finest unleaded.  Cranked it over, nothing.   I tried to bridge the relay (number 2) for the fuel pump but it primes but then stops (I thought bridging it out would make it run constantly).
As the car started before I removed the head I'm at a loss as to why it won't start.  The only 2 things that I've change from the original setup are the fuel injectors and the AFM (as it was attached to the Induction kit I bought).  I'll give my original AFM a try in the morning and I'm sure the injectors are ok as there is fuel on the spark plugs when I remove them.
Have you any ideas what else may be causing the car to start?  Any help or thoughts are appreciated.
Offline DarnPB
  • Formerly Darnpistonbroke
Re: No life in the old girl after I've refitted the head
« Reply #1 on: 17 February 2007, 23:12 »
It does sound electrical. One of the sensors has a dodgy connection or there is a wire off. You say you have replaced the injectors? Have you replaced them with the same part number?
Also check your cam timing again. That job is a bugger. Either you get it first time and its the simplest thing in the world, or you end up farting about for hours with no results.
But go round all the connections first, starting with the water sensors.
One other thing. On the end of the injector rail is a screw plug. This is where you plug in a fuel pressure guage to check your injector pressure. Remove it and make sure that when you crank the engine, fuel comes out of it. This will get rid of any air locks. Then refit it and have another go.
I am not that au fait with these engines yet, but these are the things I would check first if I had your problems. Hope this helps. Good luck. :smiley:
Offline vaughn
  • now team wagon, and team grumpy trainee
« Reply #2 on: 17 February 2007, 23:12 »
i know this may sound silly but have you checked the plugs :wink:
57 plate black 5dr ed30, 1969 bay window devon camper. thats all for now folks, hopefully picking up a wagon tomoz
Offline jaybv6
« Reply #3 on: 18 February 2007, 00:11 »
Plugs are new  :wink:
Cam timing is spot on.  I'll check all the electrical connections again and see if anything is loose etc.
Water temp sensor is also new.
Injector have been checked and they are the right part number, they've also been confirmed as working hence I know that it may not be the injectors.  Would a faulty MAF cause this issue?
Thanks for your help ;)
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #4 on: 18 February 2007, 00:22 »
Have you done a compression test? may need a tow start to fill cam followers with oil
Tom
Offline DarnPB
« Reply #5 on: 18 February 2007, 11:08 »
It could be the MAF, but if it was working before, it should work now. Try borrowing another from a mate.
Thom 89's suggestion could also be a possibility, although if the tappets were collapsed, you should still get a fire. Same as for if the tappets were overfull of oil. Well worth a tow round the block though, in gear.
Offline jaybv6
« Reply #6 on: 18 February 2007, 18:18 »
The Tappets are new.  I made sure to fill them with oil when fitting them but most of that has probably run out.  Have tried a different MAF that's known to work and still the same.  I'll try the tow thing with the old girl in gear.
Offline rowlers
  • I'm back - MK7 GTI
« Reply #7 on: 19 February 2007, 07:43 »
I had to tow my valver to get it going after new head rings and shells, after a couple of tows to get it going it then started to fire on the starter!
give it a go :wink:
Offline jaybv6
« Reply #8 on: 19 February 2007, 10:16 »
Is that normal then after fitting major engine components?  I mean to build the pressure up?  I removed the coil and cranked the engine for 10 seconds or so to do this but was unaware that it may need something more.  It would defintely explain why it's having problems starting.
I'm going to do a compression test sometime this week.
« Reply #9 on: 19 February 2007, 13:09 »
Have you checked the dizzy timing, the dizzy will spin freely once the belt is off :)
Edit: pressue should build up very quickly, I replaced the entire engine on my digifant and it didn't take long on the starter for it to fire.  Also, does the pump prime when you turn the key 1 click?
« Last Edit: 19 February 2007, 13:15 by rubjonny »
