Author Topic: No life in the old girl after I've refitted the head  (Read 3706 times)
Offline jaybv6
  • 03 Mk4 GTTDI PD 150
Re: No life in the old girl after I've refitted the head
« Reply #10 on: 19 February 2007, 21:41 »
John,
    Dizzy timing is spot on.  Pump primes and fuel is being pumped into the cylinders.  However I think that it's pumping it through too quick as the fuel is just coming out of the exhaust.
« Reply #11 on: 19 February 2007, 23:03 »
sure the timing isnt 180 degrees out?  If the pump is priming then the ecu is working, do you have a spark?
Offline jaybv6
« Reply #12 on: 19 February 2007, 23:14 »
Yes, cam lined up correctly, spark is being produced and when timing is set to fire on cylinder 1 the dizzy is in the right place.  I'll check again though.
« Reply #13 on: 20 February 2007, 00:07 »
has the blue sender been replaced?
Offline Mr Blue
« Reply #14 on: 20 February 2007, 00:28 »
i had the same problem with mine. this happend twice!
was the ignition moduel that sits ontop of the ecu.
Offline jaybv6
« Reply #15 on: 20 February 2007, 08:06 »
Quote from: rubjonny
Yes, blue sender is brand new.
Quote from: Mr Blue
Can you please be a bit more specific?  Dis you get a spark and was it turning your engine over?  Mine sparks and turns over but the fuel just isn't igniting.  It worked fine before the head removal.
The only thing that has changed is that I've removed the head, refitted the new head gasket and changed the injectors.   I'm planning to attach my old injectors (one was split) to just rule out the new ones having a higher flow rate.  Fingers crossed.
Offline bomp
« Reply #16 on: 20 February 2007, 09:20 »
HT leads on the plugs in the right order?
Life is like a skid mark on a toilet bowl.  Sooner or later someone\\\'s going to pi$$ you off.
Offline jaybv6
« Reply #17 on: 20 February 2007, 09:43 »
Yup, labelled them before taking them off  :wink:.
Firing order is correct and I get a spark but fuel is not igniting.  Stale fuel removed and fresh stuff put in just in case but nothing.
« Reply #18 on: 20 February 2007, 09:52 »
its gotta be a weak spark, or low compression if you've got fuel and the pump isn't just running continuously...
Offline Ben Lessani
« Reply #19 on: 20 February 2007, 18:08 »
whats the compression. after i refitted the head on my mums 206, it took about 1 hour of solid cranking for the pressure to build back up from 8 Bar to 14 Bar. make sure the injectors are firing properly - take them out and point them into a bucket and watch them fire.
double check the timing is 100%, its easy to be a tooth out when tensioning, although it should start, other culmulitive factors may have a funny effect.
