Have you done a compression test yet?
I have a compression tester and a couple of ignition modules you could borrow...
I'm doing a compression test this evening. I'll give you a shout John if I need to borrow an ignition module.
Would I not get a spark if the ignition module was fubar?
My plan for this evening is to disconnect the fuel pump relay. Crank the car over and build pressure up. Do a compression test and once I am happy that the compression is there then I'll reconnect the fuel pump relay and give her a go.
It might be that I've not got the pressure in the new tappets yet, possibly?
What sort of compression figure am I looking for dry and wet?
