Car audio
quick question about swapping speakers
Topic: quick question about swapping speakers (Read 3192 times)
sacvwgolf
Guest
28 December 2006, 18:42 »
hi tried searching but no luck. i was wondering i have currently have 6x4s and were hopping to add 6x9s. is it a straight swap i.e just swap wires from old speakers onto new speakers or is there more to it?
Thanks
mk2mark
Re: quick question about swapping speakers
28 December 2006, 19:27 »
Basically so long as they're not too big for the amp and assuming you've accounted for the different physical sizes.
sacvwgolf
Guest
28 December 2006, 19:33 »
what do you mean by different sizes and amp?
Bear
28 December 2006, 20:09 »
Straight swop mate.
Heyho
Here all the time
28 December 2006, 20:21 »
Wiring wise, it's a straight swap, but you won't get 6x9s in the standard locations. Better off upgrading your door speakers.
sacvwgolf
Guest
28 December 2006, 21:04 »
yeah i don't have door speakers i think i have dash speakers and rear speakers. i plan on buying better dash speakers and 6x9s to fit in my custom speaker box. i will use the wiring from the 6x4s to power the 6x9s.
sacvwgolf
Guest
Reply #6 on:
30 December 2006, 18:20 »
so when wiring the speakers does it matter which wire goes on which terminal?
mk2mark
Reply #7 on:
30 December 2006, 20:27 »
Well they'll work but if you mix the wires up you'll have speakers out of phase and you'll get frequencies being cancelling out and stuff. Short answer you need to keep the wires the same which shouldn't really be hard
sacvwgolf
Guest
Reply #8 on:
30 December 2006, 21:30 »
what does out of phase mean? , they sound ok so i might of just got lucky
mk2mark
Reply #9 on:
30 December 2006, 23:55 »
Speakers move air by shifting back and forwards, with out of phase speakers one's pushing while the other is pulling if you get me. If you're happy with the sound then don't sweat it, I doubt it'd be that noticable, but it's still something that would annoy someone like me
Car audio
