Author Topic: Why Does nobody own a 16v? I need help!  (Read 20000 times)
Offline brains
  • why didnt i buy a ford, like my dad told me????
Re: Why Does nobody own a 16v? I need help!
« Reply #20 on: 08 May 2003, 19:27 »
ITS THE HOLE THING, COUPLE OF PIPES.
WAS A BIT OF A PIG TO PUT ON BUT WELL WORTH IT.
« Last Edit: 01 January 1970, 01:00 by 1055631600 »
when i grow up i want to be a VR6
Offline brains
« Reply #21 on: 08 May 2003, 19:31 »
BOUGHT IT FROM A SHOP IN ABERDEEN CALLED CHECKPOINT, ITS LIKE A MODING SHOP HAS EVERYTHING.
judderi
« Reply #22 on: 08 May 2003, 19:31 »
does it replace the pipe/hose that connects to the throttle? P.S you on msn?
Offline brains
« Reply #23 on: 08 May 2003, 20:58 »
it conects to what ever comes from under the cover that holds the plug leads, i know very little about my golf havent had it that long, but due to this im learning more every day :P
judderi
« Reply #24 on: 12 May 2003, 14:59 »
Got another update for y brains. A mate of mine has his own diagnostics equipment, the same as the vw dealers have and he did it for free for me. saved 40 quid! anyway we cleared all errors from the ecu then went out for a thrash. got the car to judder then plugged it back into the diag. one fault appeared. knock sensor - no signal. i dont yet know where the knock sensor is but its a good bet thats the problem.
Offline brains
« Reply #25 on: 12 May 2003, 22:14 »
how was your car going without that sensor pluged in,
picking car up tomorrow garage dosent have a clue!!
judderi
« Reply #26 on: 13 May 2003, 12:57 »
if your refering to the knock sensor then i dont know cos i havent yet found it to unplug it. but if you mean how was it going with the idle stabalizeation valve unplugged, ok except for cold mornings - still juddered though.
Offline brains
« Reply #27 on: 13 May 2003, 17:04 »
been told the best way to find the problem is to get it on a rolling road with machine plugged in and them give it some welly!! the fault should then be traced, as soon as i get this sorted its getting sold so i can buy a vr6 ;D
Offline brains
« Reply #28 on: 15 May 2003, 15:25 »
the saga unfolds,
mechanic has been top class, as well as car going faulty at a certain rev band he has sussed that it its only at a certain runing temp also. changed relays, sensors and what i had done already but hes still going on with it!!
think some other people might have chucked it already, so heres to my knight in greasy overalls!!
Offline brains
« Reply #29 on: 16 May 2003, 11:01 »
i take it all back, >:(
the mechanic has bottled it, he tried but in the end failed to find the problem!!
car is being booked into a autoelectrician at the start of next week :'( :'(
