Author Topic: Why Does nobody own a 16v? I need help!  (Read 19986 times)
Offline brains
  • why didnt i buy a ford, like my dad told me????
Re: Why Does nobody own a 16v? I need help!
« Reply #10 on: 08 May 2003, 18:05 »
drove it away from garage after new sensor fitted, seemed fine went to drop a gear started doing it again.
took it back to garage to see if they could find anything else.
heres hopeing :o :o
« Last Edit: 01 January 1970, 01:00 by 1055631600 »
when i grow up i want to be a VR6
judderi
« Reply #11 on: 08 May 2003, 18:46 »
;)Brains I have good news! ;)
>:(Well i started to have idle tickover problems as well as the violent juddering. it was ticking over at 15 thou. ?>:( So i investigated and at the front of the engine under the plastic bit that the plug leads clip into is an idle controll valve. its round with 1 hose connecting into it that leads off to the air intake and an electric plug. I disconected the electric plug while the engine was running and the idle tickover dropped to normal. So i left it like that. Since then i have thrashed the living daylights out of the car and it hasnt once done the missfire judder problem thingy!!!!!!! ?:D ;D :D ;D :D ;D :D ;D :D ;D :D ;D :D ;D :D ;D
Have i at last sussed it? I thought about replacing the controll valve but it costs over 200 quid so i dont think i will bother. Will just leave it disconected i think. Does anybody know if this is safe to do?
« Last Edit: 01 January 1970, 01:00 by -1 »
Offline brains
« Reply #12 on: 08 May 2003, 18:55 »
;DGOOD SHOT KID!!! ;D
WILL WAIT TO HEAR FROM THE GARAGE TO SEE WHAT  THEY SAY, WILL MENTION IT TO THEN TO SEE WHAT HE THINKS!!!
KEEP ME UPDATED AS TO HOW YOUR GETTING ON ;)
judderi
« Reply #13 on: 08 May 2003, 18:58 »
Give it a go yself. it takes less than a second to unplug it. It could make y day! P.S forgot to ask. is yours a mk 2 16v?
Offline brains
« Reply #14 on: 08 May 2003, 19:07 »
JUST BEEN ON THE PHONE TO THE BLOKE AT GARAGE, HE SAYS THAT IS A VERY COMMON PROBLEM BUT HE THINKS IT MAY HAVE BEEN CHANGED ALREADY.
MK3
judderi
« Reply #15 on: 08 May 2003, 19:08 »
Just bloody try it! cant do no harm!
Offline brains
« Reply #16 on: 08 May 2003, 19:12 »
JUST HAD ANOTHER IDEA, HAD A PIPER CROSS INDUCTION KIT FITTED THEN CHANGED IT BACK TO ORIGINAL SYSTEM. WHAT WOULD HAPPEN IF THE SENSOR IN AIR FILTER WAS BROKEN WHAT WOULD THE SYMTOMS BE  ANY IDEAS??
judderi
« Reply #17 on: 08 May 2003, 19:15 »
Well i managed to melt the wires on the sensor together and i noticed a lack of power flow through the range, bit lumpy etc. But dont think thats y prob. P.S what did y do with the induction kit?
Offline brains
« Reply #18 on: 08 May 2003, 19:22 »
WAITING IN MY SHED UNTIL THE CAR GETS SORTED, ;D
AS SOON AS IT SORTED ITS RIGHT BACK ON!!
WHAT A NOTE YOU GET WITH IT!!
BEST ?70 I EVER SPENT ;D
judderi
« Reply #19 on: 08 May 2003, 19:24 »
Ive got a k&n but its not the propper one. previous owner put it on. does the trick but is ugly. Want to change it really. is your kit just a filter or do you get any pipes etc? P.S where did y get yrs?
