Author Topic: WUR Mod  (Read 6102 times)
Offline NewStu
Re: WUR Mod
« Reply #10 on: 02 November 2006, 16:05 »
Cant beat a good head job!  :wink:
Offline Daz...
Re: WUR Mod
« Reply #11 on: 02 November 2006, 16:27 »
I see. How big did you want to make the ports!  :shocked: Ive heard that the 16v head is overported anyway and would run better with a smaller diameter, but thats off subject and probably not even true.
Once you get the needed guage and connections can you let us all know please so we can purchase the same. Ta
The ports on the 16v's are far from oversized. It's the valves that aren't worth going bigger on unless you're goin race spec.
08.03.10 - 3, maybe 4 weeks, and I want my golf back on the road!
Offline rowlers
  • I'm back - MK7 GTI
Re: WUR Mod
« Reply #12 on: 02 November 2006, 18:58 »
bit of progress on the  bits, just need to know what size the thread is on the WUR line.
Anyone??
Offline Godzilla
  • <<<VR6 MADNESS>>>
Re: WUR Mod
« Reply #13 on: 03 November 2006, 10:02 »
Anyone fancy doing a WUR mod to my GTI valve? I dont have the bottle to do it myself!! I could bring my car to whoever can do it and also give a nice £Â£  :smiley:
Offline rowlers
Re: WUR Mod
« Reply #14 on: 03 November 2006, 10:47 »
I'll do it - if I can get the right connectors!!!
west cumbria though miles from you I guess!!!
Offline Godzilla
  • <<<VR6 MADNESS>>>
Re: WUR Mod
« Reply #15 on: 03 November 2006, 10:51 »
West cumbria is fine....could make a weekend of it with my daughter as ive heard its lovely there. What kind of power gains gan be expected from the WUR mod (im sure this question has been asked before!)
Offline NewStu
Re: WUR Mod
« Reply #16 on: 03 November 2006, 10:51 »
Do you mean the thread of the bolt that goes through the middle of the banjo?
Offline rowlers
Re: WUR Mod
« Reply #17 on: 03 November 2006, 13:31 »
no, the thread on the nut (WUR Feed fuel line) that screws onto the metering head.
the middle one in the pic above!
Offline rowlers
Re: WUR Mod
« Reply #18 on: 03 November 2006, 14:19 »
DOHDOHDOH!!
Just rememebred I have a set of Fuel lines in my shed!
Now then, I assume that the connector to the injector is the same size as the one for feed to the WUR (on the metering head). CAn anyone confirm this?  Looks identical!
Also can anyone tel me how I get the banto bolt bit out of the end of the flexible pipe with cutting it? I don't wan't to destroy it as it is a good spare and they are £40 from VW!!!
Offline Gambit
Re: WUR Mod
« Reply #19 on: 03 November 2006, 14:37 »
yes they will be the same. though will the rigid metal pipe not foul on the slam panel when you try to fit
id just chop the baitch off!! the pipes are easily found in scrap yards!!
