Author Topic: WUR Mod  (Read 6101 times)
Offline rowlers
  • I'm back - MK7 GTI
Re: WUR Mod
« Reply #20 on: 03 November 2006, 17:36 »
just need to know the thread size now so I can get the right t piece sent with the guage.
Anyone know the size?
Offline rowlers
Re: WUR Mod
« Reply #21 on: 04 January 2007, 20:37 »
still needing the bits for this mod!
anyone help out???
I've got some k-jet lines but no means of connecting them to a guage! Can't use a t-piece as the smallest diameter they come in are 6mm, k-jet lines are about 3mm!
can I jubilee clip 6mm diameter fuel line around the outside of the k-jet, will it be air/fuel tight!
I can then get a gauge with 6mm tails, and all will be hunky dory!
Offline Gambit
Re: WUR Mod
« Reply #22 on: 04 January 2007, 20:51 »
just get good quality jubilee clips and you should be grand - stick 2 on if you wanna make doubly sure!!
whats the worst can happen. it will sheer off spray petrol everywhere & explode into flames!!!
nah at worst it will seep out & you'll spot it straight away!
Offline rowlers
Re: WUR Mod
« Reply #23 on: 04 January 2007, 22:16 »
found a kit for about £13 delivered!!
I'll get some hose a give it a go!
