Author Topic: Picture of 8valve digifant alternator setup required  (Read 2153 times)
Offline golfmk2boy
« on: 18 September 2006, 15:39 »
Hi,
For some reason my alternator belt does not fit correctly, a picture of the correct setup would help....
This is a really easy one I know, but I cannot get the belt tight.... argh!!!
 :embarassed:
Offline Bluefox
  • ...back again!
Re: Picture of 8valve digifant alternator setup required
« Reply #1 on: 19 September 2006, 19:46 »
I've only just read this thread and it's dark now, but I'm working on the car tomorrow so I can post one then if it's any use?
Bluefox
Current: '84 Golf C 1.9 TDi | '01 Polo GTI | '01 Audi A2 TDi | '83 MG Metro
Previous: '83 GX | '04 R32 | '93 VR6 | '86 GTi 8v | '88 Diesel | '92 G60 | '04 Skoda Superb TDi | '90 GTi 8v | Plus many more!
Project Thread - http://www.golfgtiforum.co.uk/index.php?topic=270683.0
Offline golfmk2boy
« Reply #2 on: 20 September 2006, 20:22 »
Yes Please!. :wink:
Offline Bluefox
  • ...back again!
« Reply #3 on: 20 September 2006, 23:31 »
No probs, enjoy :)
Bluefox
Offline Bluefox
  • ...back again!
« Reply #4 on: 20 September 2006, 23:31 »
Let me know if you need any more :)
Bluefox
Offline barkstar
« Reply #5 on: 21 September 2006, 00:43 »
PAS or not? Different belts and easily mixed up by your supplier - speaking from experience  :angry:
Non PAS Length: 950mm Width: 10mm
PAS Length: 866mm Width: 11.2mm
Not a lot of difference but enough.
barkstar  :nerd:
Offline jaybv6
  • 03 Mk4 GTTDI PD 150
« Reply #6 on: 21 September 2006, 12:18 »
barkstar  :nerd:
Is that right?  The Non PAS is longer thant he PAS one?  I thought it would be the other way round.
Offline Bluefox
  • ...back again!
« Reply #7 on: 21 September 2006, 12:22 »
I'm not sure, but our golf's got PAS. All I remember is that I had a problem with the listings in halfords, so Slick & I just took the old belts in.
Barkstar, where'd you get that data from?
Bluefox
Offline golfmk2boy
« Reply #8 on: 21 September 2006, 15:08 »
Hmmm....
That looks just like mine, however my belt is insanely loose!....... Im sure it is the same belt aswell..... unless this engine, being a newer one has PAS, and the pulleys must be different, that must be the reason.
I think PAS was added by default in 90> cars....
My car is pre 90 so the belt is long now being on a 90> digifatn engine..... It must be that the pulleys are different and belts?
Does the PAS pump sit near the alternator, I poresume it would?
could this be correct?
Many thnks for the fotos!!!!
 :wink:
« Last Edit: 21 September 2006, 15:14 by golfmk2boy »
Offline Bluefox
  • ...back again!
« Reply #9 on: 22 September 2006, 12:06 »
Without looking, I think the PAS pump is towards the bottom of the engine, near the crankshaft pulley. I think...
As for lengths, not being at work atm I wouldn't know. Is the belt you've got much longer? You could always take the longer belt in and look at what they've got on the shelves, then pick a shorter one. Most places will take them back as long as they're not special order.
Bluefox
