Author Topic: Picture of 8valve digifant alternator setup required  (Read 2154 times)
Re: Picture of 8valve digifant alternator setup required
« Reply #10 on: 25 September 2006, 12:27 »
PAS was always an option on the MK2 Golf regardless of year, apart from on the special edition models and the very late run out models perhaps.
Easiest way to tell if it has PAS is to check the passenger side of the engine bay, if it has it you'll see a square bottle near the battery with a pipe coming out of each end, one running to the rack and the other round to the PAS pump on the engine block.
