Author Topic: Today's efforts towards the boot....  (Read 11008 times)
Offline Dizzie
  • Make friends with your fast
« on: 02 January 2004, 19:24 »
;D
« Last Edit: 02 January 2004, 19:25 by Dizzie »
Blue MK2
Re:Today's efforts towards the boot....
« Reply #1 on: 02 January 2004, 20:33 »
Tidy :)
You do all the install work yourself?
Offline Dizzie
« Reply #2 on: 02 January 2004, 21:03 »
yep. I borrow next door's jigsaw and get to work :)
I still need to hide those wires by the cap and get some perspex windows in there and neons to light it up. There's also a little gap between the boxes that could do with filling.
I think my alternator is about to kark it though. the amps are complaining there's 11v of juice instead of the usual 14v there should be  ??? Will investigate in the light
« Last Edit: 02 January 2004, 21:03 by Dizzie »
Offline Helios_Blue_Valver
« Reply #3 on: 02 January 2004, 22:02 »
Looking good mate. Maybe time for new alternator. How many farad cap is that?  It maybe that the cap needs time to charge and then start pumping out the 14v.  ??? Not sure.
Offline dubslug
« Reply #4 on: 02 January 2004, 22:43 »
dizzie can u show me the top bit above the cap where it meets the parcel support shelfs as i still cant work away of doing that and making it look good
1992 pearl grey 8v
Blue MK2
« Reply #5 on: 02 January 2004, 23:24 »
a mate of mine powered his huge install but attaching a seperate alternator. It was basically 2 alternators stuck together, one for the car and the other for the audio.
He used an electric motor referb company (where i used to work) to make him a seperate alternator.
Anyone else tried this?
« Last Edit: 02 January 2004, 23:24 by Blue MK2 »
Offline Dizzie
« Reply #6 on: 03 January 2004, 00:17 »
I've gotta see what voltage is across the battery first. It's a 1 farad cap. but the amp can suck 51AMPS on peak  :o I think I'll just have to keep it moderate unless I need to drive through town or something ;D
« Reply #7 on: 03 January 2004, 16:19 »
Optima red top battery may help out. They are more of a deep cycle battery.  Never heard of a dual alternator setup but i can see how it would work. Might be able to use A/C brackets and pulleys to make it fit on. Probably better off just getting an alternator re-wound to pump out a few more amps.  :) One of the people I work with was having a similar problem with the system in his car. He has 2 kicker solo-baric L7's running off of an audiofonix 2400watt amp. Too much bass for me. Makes the whole car rattle. lol
Offline jedi16v
« Reply #8 on: 09 January 2004, 22:37 »
nice install mate . got an idea for you why not go for a diesel alternator and battery . mate of mine done it and worked a treat :D
Offline Dizzie
« Reply #9 on: 09 January 2004, 23:49 »
unfortunally I'm hoping never to have a flat....
