Car audio
Today's efforts towards the boot....
Topic: Today's efforts towards the boot.... (Read 11013 times)
Helios_Blue_Valver
Re:Today's efforts towards the boot....
Reply #10 on:
10 January 2004, 00:19 »
May i recommend AA?
I guess if you have to get at it you can. Just a pain in the a55 is all.
Dizzie
Forum addict
Make friends with your fast
Reply #11 on:
10 January 2004, 00:44 »
I haven't carried a jack or wheel brace for the last 2 1/2 years
I found one in the scrappy the other day and bought it for ?4. Just in case. Trouble is if a front has a flat I've got to move a tyre from the rear cos the space saver won't go over a 280mm disc
Mk2 Golf GTi restoration -
https://youtu.be/s-Jj5bABxM8
jedi16v
GTI forum regular
Reply #12 on:
11 January 2004, 22:51 »
lol
. strap a spare wheel to the roof and start a new trend.
Blue MK2
Guest
Reply #13 on:
11 January 2004, 22:59 »
my 8v has soo much room in the engine bay. why couldnt VW put the spare in that
Dizzie
Forum addict
Reply #14 on:
15 January 2004, 00:01 »
I'm thinking about using a bonnet lifter to lift my false floor somehow. easy to get the spare out. not that I get it out much
Blue MK2
Guest
Reply #15 on:
15 January 2004, 00:11 »
now that you have 17's there is no point you having a spare that is smaller than a 17" rim. it is illegal to have an odd size rim on the car.
Ditch the spare Dizzy!
Dizzie
Forum addict
Reply #16 on:
15 January 2004, 00:34 »
well if I'm pulled over I'll say there's nothing under there and it takes ages to remove all the amps to lift the floor. just in case of an emergency it'll get me home. Only downside is if the flat is on the front I have to swap one off the back as the spacesaver won't go over the G60 discs on the front
jasonpi
Reply #17 on:
15 January 2004, 09:02 »
ive heard tyre weld is quite good as an emergency
AdamB
The Perfect Storm
Reply #18 on:
15 January 2004, 12:06 »
I've heard tyre weld is a b1tch to clean out the tyre if you want to get the thing repaired though - just call the AA out and get them to fix it or tow you home
I don't own this anymore - I just can't be arsed to change the picture
Car audio
