Author Topic: ISO Problem? What have I done?  (Read 3488 times)
Offline RaKeR
« on: 10 September 2006, 17:03 »
Hi guys,
I just tried to install my new Blaupunt Essen mp3 player.
The wiring in my Jetta has the standard ISO fittings - brown plug for the speakers and black for the ground, battery live, ignition and one other [which I'm not sure of].
I plugged them both in and the unit wouldn't come to life - I then realised that the live on the exisiting male vw loom does not match up with the live on the female blaupunkt [if you catch my drift?].
It seems that the earth is in the right place, but the live hooked up to the ignition connector on the head unit?  Qustions are thus:
1.  Have I done any damage to the headunit?
2.  Do I need an ISO adapter - if so where from??!??!
3.  Is there a tool that allows me to change the wiring in the ISO plug on the Jetta to match that of the headunit?
Argh.
Si.
Thanks in advance!
Offline Uruk Hai
Re: ISO Problem? What have I done?
« Reply #1 on: 10 September 2006, 18:39 »
Hopefully the radio you fitted has its own fuse so you should'nt have done any damage, check the inline fuses in the wiring then check the fuses in the car.
Offline RaKeR
« Reply #2 on: 10 September 2006, 18:58 »
Okay, so the back of the head unit carries a 10a fuse, so happy about that - there's no inline fuse so to speak.  The point is, is that the live on the male doesn't hook up with the live on the female on the unit - I had a look at the manual - so there's no juice going in there?
Offline Uruk Hai
« Reply #3 on: 10 September 2006, 19:00 »
Cant you just swap the wires so that they meet up ?
Offline RaKeR
« Reply #4 on: 10 September 2006, 19:30 »
I can't get the wire out of the plug!!!  How do you DOIT?!?!?!?!?   :laugh:
Offline Heyho
« Reply #5 on: 10 September 2006, 21:07 »
You'll probably need a special pin releasing tool.  A friendly ice shop might help, or google it.
Offline RaKeR
« Reply #6 on: 13 September 2006, 17:26 »
No idea's anywhere I've tried!!!  Just getting 'brute force', but I don't want to feck the plug up by yanking 'em out?
Anyone with an y other ideas?!  Or am i just gonna have to cut the wires and re-press new clips and buy a new ISO plug?
Offline Dom Mk3
  • Insert wit here
« Reply #7 on: 13 September 2006, 17:51 »
if you really don't like cutting wires, a iso/vauxhall adapter should do the trick. Basically the permanent/ignition is the wrong way round. Does the unit come to life with the key in?
Offline RaKeR
« Reply #8 on: 13 September 2006, 20:42 »
No it doesn't fire up at all?
Should it, even if the feeds are the wrong way around then?
Thanks for your reply by the way!
Offline frog
« Reply #9 on: 13 September 2006, 22:08 »
If your trying to wire it up in either a Mk2 Golf or a Jetta, then there isn't an ignition feed live wire.
The brown is earth and the red below is positive but for most modern H/units you also need a swithced live (ignition)which is normally 2 pins away from the live. Vw decided that this was to easy and have actually wired up the permanent live in place of the switched live.
Basically the live you have already is permanent and you then require a switched feed.
Halfords do sell adapter cables if you dont want to bodge your wiring
A bit long winded i know but its easier to show than to explain  :wink:
