Author Topic: ISO Problem? What have I done?  (Read 3597 times)
Offline boneybradley
  • Back in a Mk3...
Re: ISO Problem? What have I done?
« Reply #10 on: 13 September 2006, 23:29 »
I think you need one of these.......Autoleads iso connecter lead Pc2-18-4 most motor shops do these or similar.designed to convert from your original to standard iso connector check the website for more details                http://www.autoleads.co.uk/database/Jetta.html
Hopefully this help's...must also add there ain't a whole lotta room at the back of the sterio cage but a bit of convincing and your radio will clip in ok
Offline RaKeR
« Reply #11 on: 14 September 2006, 20:08 »
Cheers Frog and cheers boneybradley,
Great stuff - I'll see if I can find one in Halfrauds that I can grab right away.  Otherwise I'll order one in!
Outstanding.  I love this forum - it's saved the day once again.
 :grin:
  • Back in a Mk3...
« Reply #13 on: 14 September 2006, 20:31 »
Going by desciption it sounds like the one.....Only thing i have found is on some sterio's the switching and permanant lives can be switched and the auto leads one has pre crimped connectors to sort this...but a couple of bullit's will sort it for you :nerd:
Offline RaKeR
« Reply #14 on: 15 September 2006, 22:16 »
Okay, so I bought the Autolead part - the stereo now orks just fine - except for that when I switch it off, the chuffin' illumination stays on.  AAARRGGGHH!!!
I noticed that there is an illumination lead that goes into the head unit on the iso adapter.  Is this the cause maybe?
Damn thing.
