Author Topic: CALLING MK3 VR6 FITTED WITH CORRADO VR6 2.9THORTTLE BODY AND LIGHT WEIGHT CRANK  (Read 5565 times)
Offline faigolfgti
I plan to change my mk3 vr6 thorttle body to corrado vr6 2.9 big thorttle body and the second plan is to change my original big heavy crank pulley to light weight crank pulley please advise me is it a good idea to do that and is it going to make my vr6 faster?Thank You.
Offline faigolfgti
Offline AudiA8Quattro
Corrado VR6 throttle body and upper inlet manifold will give gains.
Lightened flywheel is a worthwhile upgrade as well.
Offline Jack3559
Whoa, five years on and he's still going!
Offline benvictors
  • bgk Tuning - coming soon!!!
The throttle body on its own will give you no gains at all, but as said before, coupled with the 2.9 inlet manifold and you will gain yourself a few ponies  :grin:
Offline Ess_Three
Yes it will.
The Corrado VR6 TB is far better than the Golf VR6 2.8 TB. I've swapped several and seen repeatable gains of 2-3 BHP...not a lot admittedly, but combined with a modified airbox and panel filter, it gives 5-6 BHP genuine.
The Corrado VR6 inlet manifold gives better throttle response too, due to it's larger internal volume.
It will give no more top end power because the port sizes are the same.
..but gaining motorcycles.
Offline Ess_Three
Yeah, more so than a lightened crank.
The flywheel makes a noticable difference...the crank will make no difference if you bolt it to the damn great lump of pig iron that is the standard flywheel.
The standard VR6 crank is not badly balanced as it is, so little need to mes with it.
It's perfectly fine up to 7500 RPM, and to be making power up there you will be into different cams anyway...so on a standard engine, no point in messing with it.
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Has this guy been in a coma for the last 5 years or something?  :shocked:
Offline tweed
if he aint done it in 5 years he aint gonna do it now. we will get another reply in couple of years.
