Author Topic: Just a few questions regarding wheels...  (Read 1637 times)
Offline Optimus Wol
  • Theres an evil monkey in my closet......
« on: 08 August 2006, 23:15 »
basically, i wanna go for 16"x9j. whats the best offset for the mk2's?? and anybody running on 9j rims on here? any problems?
and before i go, whats the PCD for a mk2 16v on a H plate? 4 stud before i forget. cheers people, much obligided  :cool:
Offline takethefifth
Re: Just a few questions regarding wheels...
« Reply #1 on: 08 August 2006, 23:26 »
Hi, PCD is 4x100 and you will need some arch work though not done it myself.  :smiley: Not sure what offset would be best on those wheels, stock is somewhere around 35 i think...
Offline Optimus Wol
« Reply #2 on: 08 August 2006, 23:33 »
cheers mate. just so im sure, if its a smaller ET number, its more offset aint it? cant remember. aint done it since college............   :undecided:
« Reply #3 on: 09 August 2006, 03:03 »
Yep, ET measured in millimetres and the lower it is, the further the wheel sticks out.  :smiley:
Offline ...joe
« Reply #4 on: 09 August 2006, 09:45 »
^^^ a wheel with an et of 5 (for example) will stick out loads and one of 50 will stick in. 9x16's will definately needs ome sort of arch work unless you're planning on leaving it stock ride height... which would look sh!tter than sh!t!
i've got 8.5x15's with a low drop and had to have alot of chopping done!
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline topher
  • Administrator
  • fully functioning
« Reply #5 on: 09 August 2006, 09:50 »
9" wheels should have an offset of 15mm if i remember rightly to avoid collisions on the inside of the wheel.
Mine are 9x16 with a pretty substantial drop and stretched/low profile tyres.. still rubs occasionally, and thats with rallye arches. Get yer tinsnips out :grin:
Offline VR6_ROB
  • Mk2 VR6 / Corrado G60
« Reply #6 on: 09 August 2006, 12:53 »
so if i get borbet type A 9x16 ive go tot do a lot of arch work
or could i get spacers so they sit further out
Judderi
« Reply #7 on: 09 August 2006, 13:05 »
Further out would make it worse cos thats where the arches are.
Offline Organisys
  • Old and Slow...
« Reply #8 on: 09 August 2006, 13:17 »
Surely at 9" wide you are going to need some arch work regardless of ride height and offset, wont the tread of the tyre be just out of the arch? either that or he is gonna need a big stretch on the rubber.
Judderi
« Reply #9 on: 09 August 2006, 13:27 »
i agree. for the hastle id say its not wort it and go for a different size.
