I'm running Borbet type A wheels, 9x16 rear 7.5x16 front. You wont have a problem with the front but don't use 215/40/16's on the back if you corner hard, you'll end up running on the tyre walls, trim and role the rear arch lip, trim and put the plastic arch cover back on. You'll be able to run 215/45's on the back. Because of the amount of grip you'll generate with fat rubber front lower and rear strutbraces worked wonders on mine.
