Author Topic: popping  (Read 4541 times)
Offline VR6_ROB
  • Mk2 VR6 / Corrado G60
popping
« on: 15 May 2006, 22:56 »
hey all
when i change gear in my mk2 8v gti
if im driving rather fast it seems to pop out of the exhaust
and also now and again car does not feel very fit when driving
and when i pump the accelerater it pops out the exhaust
and seems to be ok bit after that
how can i stop it doin this my white gti never did it
Offline frog
Re: popping
« Reply #1 on: 15 May 2006, 23:06 »
check your timing!
Judderi
Re: popping
« Reply #2 on: 16 May 2006, 11:55 »
Hows the vr6 conversion coming on?
Offline Gambit
Re: popping
« Reply #3 on: 16 May 2006, 12:14 »
since i removed the centre silencer on mine it will pop on gear change under hard acceleration
Offline Dub_Dude_16v
  • Sunny Hertfordshire!
Re: popping
« Reply #4 on: 16 May 2006, 12:17 »
Lucky gits! Got a full stainless system on mine and i don't get the popping noise  :angry:
lol although on my old 1.3 mk2 i had a straight through stainless system with just a dtm back box. Used to pop so loud when i let off that it would send flames out the back and cause people to fall flat on their arse  :grin: :laugh: :grin:
Just thought i would hijack the thread with my thoughts and experiences   :wink:
I'll get me coat  :rolleyes:
Offline Organisys
  • Old and Slow...
Re: popping
« Reply #5 on: 16 May 2006, 12:50 »
Popping is caused by overfueling or unburnt fuel making it into the exhaust.
Check timing first.
Offline Noggin
Re: popping
« Reply #6 on: 16 May 2006, 12:56 »
My 8v GTi does the same on gearchanges under heavy accelerating and when backing off the throttle
have recently timing and mixture reset and it still does it
Veedubgt18v
Re: popping
« Reply #7 on: 16 May 2006, 15:13 »
check your exhaust is sealed properly at the joints aswell this can cause it. i can get mine to pop if im acelerating hard however my timing etc and joints are fine
Offline Mk1Mad J - 16v
  • At my age I don't have to act responsibly...
Re: popping
« Reply #8 on: 16 May 2006, 15:33 »
Check timing first.
Damn!!! beat me to it  :wink:
 :nerd: If your exhaust is leaking (crack or whatever) this will make the car run rich (overfueling) and will have the same effect - simple exhaust check - put your hand over the tailpipe to block it (use a rag if its really hot) - the car should stall quite quickly,  if not you've got a leak (you'll hear the air coming out of it :nerd:) if its a particulary fiesty car you might have trouble blocking the tailpipe  :grin:
"Ever since I started to surf, I have realized that golf is for people who don't know how to surf."  -- Tiger Woods.
my dub project:-
http://www.golfgtiforum.co.uk/index.php?topic=35338.0
http://www.youtube.com/watch?v=WyEUOoH_xxo
Veedubgt18v
Re: popping
« Reply #9 on: 16 May 2006, 15:36 »
lol im scared to check my exhaust like that cos i dont want all the exhaust sealant crud to fall out lol but i dont think it leaks sounds cool when im mega booting it tho
