Author Topic: who's the proud new owner of...  (Read 4608 times)
Offline Dizzie
  • Make friends with your fast
« on: 03 December 2003, 17:05 »
.. a mk3 dash and all the bits that go with it. It just took me 3 hours to pull it out of a mk3 driver at the local scrapper. Lucky for me someone had all ready taken the 'box out so I could stand in the engine bay to undo things.
There's about 30 bits that make up the dash including all the blanking plates, heater vents and such. About 400 screws and clips that hold it all together (no wonder the mk3 is heavy!) all in all it cost me ?45 including the heater matrix that he wants back if I don't use it and the dials and the loom so I can solder the mk3 and mk2 together so I can hook up the switches.
I grabbed the main bulkhead too. most of the dash was bolted to it so I guess I need that. Just requires a bit of cutting to squeeze in and bolt to the sides :)
I shall take piccys when it's all laid out in my garage. atm it can stay in my boot until tomorrow when I unload.
Now I'm going to have a shower and collapse before I had to goto work for 4 hours
the life of a dubber!
kniterider
Re:who's the proud new owner of...
« Reply #1 on: 03 December 2003, 17:10 »
nice 1 dizzie, youll have to take step by step pics when you install and set up a how to guide for other members that may wanna see how yav done it!! ;D
Offline Dizzie
« Reply #2 on: 03 December 2003, 17:15 »
I intend to. I've found 2 'how to' guides on the web, but nothing really step-by-step showing all the pitfalls and really hard bits. as far as the pulling it out goes you just have to remove all the screws and pull. then find another screw you missed and pull again. oh look, there's another 2 there. lol. the mk3 has so many hidden behind push in covers.
Blue MK2
« Reply #3 on: 03 December 2003, 17:44 »
Dizzy this will be very interesting mate. Ive seen the 'how to' guides on the net but there not very detailed.
plz plz take details of the heating system because ive heard you have to channel your own heating to the vents.
Good luck ;D
Offline Overseer
« Reply #4 on: 03 December 2003, 17:46 »
hey i've got one of them! lol
i need a 'new' bit tho, i put a little crack in that bit where the central heater vents are at the top.. not serious.. but its buggin as i did it when i was fitting my new head unit
Blue MK2
« Reply #5 on: 03 December 2003, 17:49 »
u got pics overseer? Does the mk3 dash look good? does it squeek/rattle when you go over bumps?
just asking coz my mk2 dash squeeks where the fog switch is VERY ANNOYING! >:(
Offline Dizzie
« Reply #6 on: 03 December 2003, 18:07 »
I'm still confused where the fog switch is on the mk3. you can pull the light switch towards you. is that the rear fog switch?
How to wire up various switches would be a god send if you've got them Overseer. I grabbed the loom so I've got the plugs
Offline Overseer
« Reply #7 on: 03 December 2003, 18:27 »
lol.. guys.. if u didnt notice i have a mk3 :)
i have a rattle over on the right i need to find.. but i'm hoping that it was a can of deicer i removed from the door pocket.. gotta remember to try again
dizzie.. ya got it, the fogs are twist to full beam, then pull out :)
Offline Dizzie
« Reply #8 on: 04 December 2003, 00:07 »
cheers overseer. Now to figure out how to wire that little lot up.
Here's a piccy of it laid out on my bedroom floor with my old heady in there to fill to space.
I don't think I'm gonna be able to wire up the mk3 clocks to the mk2 loom. so I'll look into leaving my white dialed clocks that glow blue at night in. The new oil pressure gauge I bought last week will have to move to the A pillar on a double pod with the oil temp gauge soon to arrive so the boost gauge can sit next to the headunit in that little 'made for' space.
Due to the new Kenwood MASK stereos having the controls stuck out on the back of the blank panel it leaves a couple of lines out of view when mounted high up in the mk2. Hopefully in this dash that won't be a problem. I also plan to mount my in-line bass controller in one of the blank covers by the heated window switch. the HWS should be easy enough to wire up as I'll look what the mk2's is like and just solder on the new plug sourced from the dashless mk3. ;D
I'll be writting a huge article on how to do this for all you people out there that are thinking about it so don't worry* I sugest if you are thinking about a mk3 dash swap then go take it out yourself and learn how it came apart. that's half the battle knowing exactly what goes where. also make sure you get everything that's there. I'll pop back out to the scrappy tomorrow and take a pic of the car I took the dash from to show you what you need to take.
Offline Overseer
« Reply #9 on: 04 December 2003, 00:22 »
what year mk3 is that from?
and was it a gti?
i got extra buttons in places where they couldnt be on that dash.. like for the heated seats,
(its very similar tho)
btw are u missing the sliding blanking plate for the diagnostics socket cover? (next to the ashtray?)
i'll get some shots of mine soon... need em to point out where switches go when ppl ask anyways ;)
