Author Topic: who's the proud new owner of...  (Read 4603 times)
Offline Dizzie
  • Make friends with your fast
Re:who's the proud new owner of...
« Reply #10 on: 04 December 2003, 00:28 »
it was from a M reg Driver. not a Gti. No MFA button on the stalks. I like the '90 spec MK2 stalks anyway. I think I got just about everything from the mk3 when I gutted it.
no I just found that. thanks for saying it slid on. It had me foxed trying to get it on there. back on now :)
Offline Dizzie
« Reply #11 on: 04 December 2003, 00:37 »
OMG :o
how mutha fscking great!!!!
The pins have the same numbers on the mk2 heated rear window switch as the new mk3 one does.
that makes the rewiring piss easy ;D
kniterider
« Reply #12 on: 04 December 2003, 20:15 »
dont think it should be too hard any way dizzie if you got the loom from the mk3!!, how does the mileage work on the mk3 its digital aint it?? dose it work off a counter or cable!!!, that could be a bit of a bind!! if it works off the counter/sensor type system youll need the sensor form the gear box, i think any way!, i had a yuk yuk astra sri many many years ago and banged a gte digi dash in, ha dno cable so i had to go back and get the thingyer/sensor form the gear box of the same car as would match with any other!, dunno if similar on vw?
Offline modulater
« Reply #13 on: 04 December 2003, 20:38 »
Be good to see it all in when its done dizzie. Does it go in without cutting any of it off ?
Blue MK2
« Reply #14 on: 04 December 2003, 21:07 »
you have to peal back the dashboard finishing near the windscreen and cut under that for a snugg fit.
Offline Dizzie
« Reply #15 on: 05 December 2003, 14:01 »
basically yes. you have to cut the sides down a bit (cos it's too wide) and then trim it up where it meets the windscreen. once that's done and you can hold it in place it's time to attach the support beam. with that in you can practically bolt it in. there's the small task of linking up the heating tubes and drilling more holes in the bulkhead for it to come through. I really want to get the loom spliced together before I bolt/weld the supoprt beam in. at least everything's out of the way then so I can work easier.
Whilst collecting a wing from VW today I asked if there were any diagrams to aid me wiring up the mk3 clocks, but I need the VIN number to do that. Back to the scrappy then.
Offline Dizzie
« Reply #16 on: 06 December 2003, 01:41 »
right. Found a wiring diagram on the net and spent the last hour working out what goes where. I think I've got it now. The miles must count off the speedo cos there's no separate wire for them. I don't think there is anyway. Most of them like the indicator, high-beam, etc lights are just power up and earth jobbies. I'll wire up a 12v soon to test this theory...
Now that I've got this far it's looking fairly easy. (famous last words)
The Vehicle speed sensor I need to register the speed... can I just take one off a mk3 in the scrappy?
Blue MK2
« Reply #17 on: 06 December 2003, 10:33 »
I think you might have to buy one. If you can get one of a MK3 then its a brucy bonus.
Where would this sensor be located on the mk3? Gearbox?
