Author Topic: 20vt mounts 4 a mk1  (Read 3057 times)
Offline foxy mk1
20vt mounts 4 a mk1
« on: 21 April 2006, 16:59 »
hi guys im new 2 the site & wonderd if there is anywhere i can get mounts 4 20v converion thnx  :sad:
Offline mk1
Re: 20vt mounts 4 a mk1
« Reply #1 on: 26 April 2006, 21:02 »
Is this for mounting the gear box?.
Steve.
Offline foxy mk1
« Reply #2 on: 26 April 2006, 22:22 »
hi mate, no its the o/s mount as i am using the standard box
Offline benmk1
« Reply #3 on: 28 April 2006, 10:41 »
Hopefully you don't mean the standard mk1 box!
I don't look at porn much,
usually 2 or 3 minutes is enough
Offline foxy mk1
« Reply #4 on: 14 May 2006, 18:04 »
sorry not been in touch, was working away, y not use standard box :undecided:
Offline foxy mk1
« Reply #5 on: 14 May 2006, 18:11 »
benmk1 pls ring me 07838169703 thnx
Offline benmk1
« Reply #6 on: 15 May 2006, 09:25 »
Sorry mate didn't think that the rod box was compatable, done some further investigating and it can be used highly :embarassed: don't listen to fools like me who haven't done such converstions. I sure you've looked into this conversion, and whats required, i just thought that the box had to be cable change and couldn't cope with nearly or double the power (depending on engine spec obv)
Again I sorry to have caused concern, there's loads of converion help on here, just not from me!  :sad: :embarassed: :rolleyes:
However what with the know diff pin failure from the 020 box i'd stongly recomend and upgrade!!
This fella is using a seat ibiza 16v box, handy links:
 http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=4534&postdays=0&postorder=asc&start=10
http://www.pajalle.com/cars.php?id=021&lang=en
« Last Edit: 18 May 2006, 09:13 by benmk1 »
Offline Dizzie
  • Make friends with your fast
« Reply #7 on: 22 May 2006, 10:00 »
the standard 020 'box will take 190-200bhp before it lets go. The conversion to 02A is fairly straight forward and will handle the increase in power.
Mk4 Golf 150PD
Offline Dizzie
« Reply #8 on: 13 June 2006, 21:44 »
you will need to have a custom mount made up in order to mount the 02A box to the mk1 mount. Not sure if these parts are on the shelf as I haven't researched it myself :)
Mk4 Golf 150PD
Offline pitchy
« Reply #9 on: 14 June 2006, 14:25 »
i can quite happily provide the mount if you could get me all dimensions etc , if theres enough info i can have it done in a few days . give us a shout if your interested . :smiley:
2002 gti aum mods-cai / n75j / 007p / stg1 remap / rs4 reps .
things done in the last few months - new temp sensor / new gearbox oil / anni matts / painted interior trim / debadged /
things to do - refurb wheels-satin black / coilovers / paint headlights internals black / fit fmic / 3" turbo back / stg2 remap
