Author Topic: temperature  (Read 2647 times)
Offline VR6_ROB
  • Mk2 VR6 / Corrado G60
Re: temperature
« Reply #20 on: 20 April 2006, 18:08 »
my fan deffo does not work
not drinkin alot of water unless i go rather fast
my oil is still ok temperature stays in middle where it should be
oil temp is 92
goin to change radiator and fan on weekend as i have spare ones
or maybe just thermostat see if that does out
Offline VR6_ROB
Re: temperature
« Reply #21 on: 29 April 2006, 15:00 »
all fine and dandy now
changed thermostat and the fan today kicked in once it got warm
i think i found the water problem as its been drinkin alot since i bought it
the water flange on the front of the head and on the side has a tiny leak
i noticed when i was puttin water back in so i will change gaskets tomorrow
but i still dont no why my heaters wont warm up
any other things i can check to make them work?
Re: temperature
« Reply #22 on: 29 April 2006, 16:05 »
common places for leaks those, just get 2 new ones from VW, the plastic ones can warp with age.  As for heaters, have you taken the bypass valves out yet?
Offline VR6_ROB
Re: temperature
« Reply #23 on: 29 April 2006, 17:38 »
where are the bypass valves
Re: temperature
« Reply #24 on: 29 April 2006, 18:21 »
follow the feed & return pipes to the matrix, they're next to each other and pass through the back of the engine bay.  If there is a pair of valves chopped into them with a smaller pipe between the 2, you have the bypass valves fitted.  Either remove and patch the ends together with some copper pipeing, or buy 2 new uncut hoses for £10 each from GSF.
