Author Topic: temperature  (Read 2642 times)
Offline VR6_ROB
  • Mk2 VR6 / Corrado G60
temperature
« on: 16 April 2006, 16:49 »
only just got the car yesterday
today the temp light started flashing
but the temp does not go up needle stays in middle where it should be
i aint checked anything yet what should i look for
i no water is low could it be that tellin me to put some in?
Offline [han]
  • Graphic Designer for Haribo
Re: temperature
« Reply #1 on: 16 April 2006, 16:55 »
i'd top up with water if it's low n see how it goes....
if u kno its low fil it up... poor car!
Offline takethefifth
Re: temperature
« Reply #2 on: 16 April 2006, 17:07 »
Yeh the original coolant bottles have a level sensor to tell you to top it up! Handily it flashes on the temp gauge scaring the bejesus outta you! :smiley:
Offline VR6_ROB
Re: temperature
« Reply #3 on: 16 April 2006, 17:43 »
should be ok then ill top it up when it cools down
think thats all it needs
gonna get a good service steam clean engine as its filthy
then should be ok
Offline VR6_ROB
Re: temperature
« Reply #4 on: 17 April 2006, 23:21 »
ok folks
i filled water up this mornign light stopped flashing got in it tonight to take misses home
flashin again had a look drank most of the water
and the heaters inside wont warm up?
seems to be first problem hope its summat daft
any ideas?
cheers
Rob
Offline KINGS>
  • Watch out for the guns.....
Re: temperature
« Reply #5 on: 17 April 2006, 23:26 »
what engine is it??? either leaking from the valve for the heater matrix, headasket has gone, split hose, gasket on water pump fcuked
Offline VR6_ROB
Re: temperature
« Reply #6 on: 17 April 2006, 23:36 »
8v digi G reg
no leaks or puddles
will it be ok if i keep topping it up
Offline KINGS>
Re: temperature
« Reply #7 on: 17 April 2006, 23:47 »
i had a similar problem... it turned out to be headgasket blown between first 2 cylinders, just dont rev 2 high ubtil its checked out
Offline VR6_ROB
Re: temperature
« Reply #8 on: 17 April 2006, 23:49 »
right i think ill crawl about for now then more expense only had it 3 days
Re: temperature
« Reply #9 on: 18 April 2006, 13:32 »
replace the plastic flanges on the front & right side of the block, and take a close look at the radiator.  Helps if you take off the grill & rad fan shroud.
