Author Topic: temperature  (Read 2646 times)
Offline VR6_ROB
  • Mk2 VR6 / Corrado G60
Re: temperature
« Reply #10 on: 18 April 2006, 18:20 »
had a look today still no leaks
i got a feeling my fan dont work as i have never heard it kick in yet
i might change the fan and radiator on the weekend
as i have a spare
still driving ok so far think it needs a service though
backbox sounds crap sounds rough so i will put my sytem on from the white one
and the gear stick is rather floppy so ill change that with my old one aswell
see if it improves ill check water tonight see if it goes down
oh and if i rev it tappin the pedal it pops what stops that
is it running to rich?
all help appreciated
cheers
Rob
Offline bulk66
  • Im broke an it aint a joke!!!!
Re: temperature
« Reply #11 on: 19 April 2006, 00:27 »
Could just be a air lock mate.
Offline steviem
Re: temperature
« Reply #12 on: 19 April 2006, 16:15 »
No point in starting a new thread, when this is pretty much related...
I ended up taking out my radiator in the long running saga of decontaminating my coolant system. Now it is all clean inside, and I reinstalled it, the entire radiator gets hot now, I let the oil temp on the MFA get to 90oC but the fan doesnt kick in  :sad: I have bridged the connector to see if the fan works still and it does. What sort of temperature is it meant to get to before the fan kicks in?
Also, if i have to get a new thermostat for the radiator, or a new radiator where is the best place?
Re: temperature
« Reply #13 on: 19 April 2006, 17:24 »
it should kick in about 3/4 on the temp gauge :)
Offline bulk66
Re: temperature
« Reply #14 on: 19 April 2006, 23:35 »
I had both thermostat and rad from gfs.  (gsfcarparts.com) (rad 16v gti part no is 17333 or 8v is 17332) Good quality stuff at a good price  :wink:
« Last Edit: 19 April 2006, 23:37 by bulk66 »
Re: temperature
« Reply #15 on: 19 April 2006, 23:51 »
check out AVS too:
http://www.vwspares.co.uk
Just as good if not better than GSF, shame they don't have as many parts in stock!
Offline steviem
Re: temperature
« Reply #16 on: 20 April 2006, 15:14 »
Well, got up to 3/4 water temp, and kapow! the fan kicked into life!!
although, i think i may have found out why i keep losing a bit of water, there is a screw where the hose back to the expansion tank should be...so it looks like a new radiator for me anyways...
Re: temperature
« Reply #17 on: 20 April 2006, 15:21 »
so you dont have the small hose at all?  Interesting!  If so you might want to consider fitting a MK3 2e flange at the front of the block, there is a connection here for the header tank hose.  You also have to swap the 2e waterpump/oil cooler hoses on as well, but prob all cheaper than a new radiator!
Offline steviem
Re: temperature
« Reply #18 on: 20 April 2006, 15:25 »
The small hose at the top of the header tank is there, it just looks like someones put a plug or bung into the end of it, when I looked at it before i just thought 'whats the point in that hose', now I know...
Re: temperature
« Reply #19 on: 20 April 2006, 15:40 »
ah cool, get the 2e flange then (assuming you have an 8v??):
http://www.vwspares.co.uk/product_info.php?products_id=2249
Also has clips for the sparky wires.  Tidys the engine bay up nicely :)
