Probably been asked time and time again but I have searched the forum and only seem to be able to find bits and pieces of advice, nothing conclusive really.
I have a Mk2 1.8 8v digifant and have just got my hands on a 2.0 8v engine from a mk3 (2e engine code) so wanted to know if anybody could provide me with a list or possible step-by-step guide as to the conversion?
The engine didn't come with the dizzy or the power steering pump unfortunately but I've read the power steering pump from my pb will bolt straight on (looks the same fittings). The main confusion I'm having is to specifics such as what dizzy to use. Seen a few posts saying use the 2e dizzy but then I have seen other posts about spacers and bigger gear to convert the PB dizzy?
Have pulled the engine to pieces (not fully yet, just split to sump/block/head) and the pistons don't look pitted so might get away with not having to do a full re-build however I will still be replacing the piston rings, belts, bolts/fastenings and gaskets (so any advice on which gaskets etc. would be great)
Thanks in advance
Ian
