Author Topic: changed engine over but damn thing wont run- help  (Read 6897 times)
Re: changed engine over but damn thing wont run- help
« Reply #40 on: 10 April 2006, 12:35 »
does the fuel pump prime? Does it stink of fuel?  Getting a spark?
Veedubgt18v
« Reply #41 on: 10 April 2006, 15:23 »
and the plugs/leads/etc are definately in good nick?
Offline SarahD
« Reply #42 on: 10 April 2006, 16:04 »
yep and yep, plugs are soaking, and its sparking but just not firing!!!!!! got magnecore leads on and plugs are fine too :cry:
« Reply #43 on: 10 April 2006, 16:15 »
so when you turn the key 1 click the pump runs for a few seconds then stops?
Offline jezza16v
« Reply #44 on: 10 April 2006, 16:22 »
OK, a last resort here.....   Lets assume that the dizzy is located 90 or 180 or 135 deg out to the standard.
1.  Check the leads going into the cap and double check the clockwise order is 1324,1324,1324 regardless of where the #1 lead is plugged in.
2.  If the above is true, unplug the leads from the top of the dizzy cap and move them all 'clockwise' by one position, (they will still be 13241324 but shifted through 90deg) and try again........
3.  If no go then move them all clockwise again by one position, (ie 13241324 but now shifted 180deg) and try again.......
4.  If no go then move them all again by one position clockwise (ie now 235 deg shift) and try again. If no go again, get your angle grinder out!!!!  :wink:
Offline SarahD
« Reply #45 on: 10 April 2006, 18:02 »
yep and plugs are soaking when you take em out
Offline kingtut
« Reply #46 on: 10 April 2006, 18:18 »
same problem i had...............................
bad earth or blue sender needs changing.
Sticking around for added value-;>)
Offline SarahD
« Reply #47 on: 10 April 2006, 19:18 »
can anybody give me a list of where all the specific earth points are on a mk2 8v?
« Reply #48 on: 10 April 2006, 19:34 »
one to the gearbox, several to engine block to the flange on the RHS and the rocker cover, one from coil to rocker cover several on the battery.
Put a new blue temp sender on as it will never start with a broken one.
Offline Agreeable Slick
  • Unit
« Reply #49 on: 10 April 2006, 19:39 »
same as on an 8v i presume. Oh and cylinder 1 is the one closest the drivers side wing.
