Golf mk2
changed engine over but damn thing wont run- help
4
5
6
7
Topic: changed engine over but damn thing wont run- help (Read 6923 times)
SarahD
Here all the time
Re: changed engine over but damn thing wont run- help
Reply #30 on:
09 April 2006, 16:19 »
well ive done it that way and that wont work, its turning slower than it was now
explain it step by step?
#1 on the head goes where?
and same for other 3
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
Reply #31 on:
09 April 2006, 16:24 »
#1 lead, runs to the dizzy terminal which matches up to the notch in the dizzy housing, or where the rotor arm is pointing when the engine is at TDC
Check the line on the crank pullet lines up with the arrow on the cambelt cover, and the punch mark on the back of the cam sprocket lines up with the top of the head with the rocker cover removed.
Mr Blue
Forum addict
Reply #32 on:
09 April 2006, 16:30 »
if your timing is right. check your ignition moduel (the thing that sits ontop of the ecu)
ive fried mine 4 times
jezza16v
Reply #33 on:
09 April 2006, 16:40 »
leads on the dizzy cap #1 top left, #3 top right, #4 bottom right, #2 bottom left..try that. Come back if it does not work.
Engine turning slower could mean the battery is getting flat!
rubjonny
10k hero
Reply #34 on:
09 April 2006, 16:53 »
Just to clear up ALL the confusion:
NicolaLane
Guest
Reply #35 on:
09 April 2006, 22:18 »
thats bloody good that RJ!!!!
have you ever thought of trying out for BluePeter!!
rubjonny
10k hero
Reply #36 on:
09 April 2006, 23:42 »
Veedubgt18v
Guest
Reply #37 on:
10 April 2006, 10:39 »
SarahD
Here all the time
Reply #38 on:
10 April 2006, 12:24 »
Quote from: rubjonny on 09 April 2006, 16:53
fookin lovin the picture!!!! gunna do that now, and come back when it dont work again lol
SarahD
Here all the time
Reply #39 on:
10 April 2006, 12:32 »
no joy at all, still the same as it was, im ready to give up now mind, if my mate dont fix it tonight i may get the angle grinder out
4
5
6
7
Golf mk2
